'77 Holiday Rambler Wide World - here we go!
Re: '77 Holiday Rambler Wide World - here we go!
Postby djdawg » Tue Jun 25, 2013 10:14 am
I'm still unclear about how to exactly replace part a moldy stud. Let's say I have an 8 foot stud but only about 6 inches of it is moldy. Do I replace the whole board or do I just cut off about 10 inches of it? And if it's the latter how do I connect the new, short piece to the existing longer piece? The only way I could think of is cutting a small piece of plywood that is the same width and slapping it over both boards, connecting them... but it seems like there would be a better way. Maybe this is where a Kreg Jig would come in handy? I'm reading about a Harbor Freight version that is getting good reviews.
Kevin
Bellingham, WA
djdawg
Postby CarlLaFong » Tue Jun 25, 2013 11:20 am
Lots of questions, lots of issues. I think you need a game plan instead of jumping in willy nilly. The first thing you need to do is get all the loose stuff and crap out of the trailer. Then assess the damage. It seems that you've done that. Repair the damaged areas and toss the stuff that is beyond help. Your idea of replacing just the bad part of a stud will be OK. Once the skin is off, you may find it is just as easy to replace the whole thing. I built these things for a living back in the 70s and they are pretty low tech. Lots of 2X2s and staples.
The "trip" on the breakers indicates, ironically enough, that the breaker has tripped. push it to the "off" position, then to "on" to reset them. Has nothing to do with going on a trip
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Postby tac422 » Tue Jun 25, 2013 12:08 pm
I don't have any practical experience with TT's ...
But I think you could cut out the bad piece of 2by2, then drill a hole in the remaining piece and the new piece, insert a dowel rod into both pieces and then glue them together.
And I'd try cleaning and waxing the outside aluminum before you think about painting or replacing it . I suspect it will clean up nicely.
The decals should be able to be removed, maybe by soaking in WD40 or Goo Gone ?
tac422
Postby djdawg » Tue Jun 25, 2013 1:01 pm
Ha ha...thanks guys. I'm laughing at myself with how much i don't know...trip switches. Lol! Thanks Carl! Yes I have tons of questions and I appreciate everyones patience so much. I'm hoping this weekend I will be able to start pulling up the floor and eventually make a trip to the dump. part of why I'm hesitant is because I don't have the trailer undercover yet and I don't want to start repairing things until I do but I can get started. that's why I'm doing some odd things like the stove top... things that I can repair that won't be affected by the build as I go.
Kevin
Bellingham, WA
djdawg
Postby KCStudly » Tue Jun 25, 2013 3:20 pm
I would consider doing half laps to splice the new stud parts back to the old stud parts. Cut the bad out, then cut 4 or 6 inches more, but only half way. Kind of like two letter L's overlapping. Then you can glue and screw them together thru the face into each other.
The plywood splice plate you described is not a bad idea either, but adds weight and may not have room for it in some locations. Using a pocket screw jig to tie the shoulders of the lap joints together would make it even more rigid (the shoulder cuts can create a weak spot depending on the direction of loading).
You have a huge project in front of you there. Are you sure you're ready for this? :thinking:
Postby djdawg » Tue Jun 25, 2013 4:06 pm
KCStudly wrote:I would consider doing half laps to splice the new stud parts back to the old stud parts. Cut the bad out, then cut 4 or 6 inches more, but only half way. Kind of like two letter L's overlapping. Then you can glue and screw them together thru the face into each other.
Love your idea KC about doing "L" cuts....that's a great idea. And no...I'm not sure. :) But it's something I want to do and my kids are older....I have no wife or gf...no dog. I have time. Ha ha What's the best saw to use for doing cuts like that?
Kevin
Bellingham, WA
djdawg
Postby KCStudly » Tue Jun 25, 2013 9:19 pm
Depending on accessibility, a small panel saw (radial) set to a shallow depth to make the cross cut at the step and set the depth. To clean the rest of the "notch" I would consider a jigsaw, but it might be just as quick, and more accurate to kerf out the rest with the panel saw (fixing the depth of cut accurately) and knock the fins out with a chisel. If the remaining stud can be easily removed (depending on the degree of dis-assembly required by the state of repair, it would probably be easier to get a good tight joint by milling the notches on a router table or table saw with dado head.
Having said all that, the plywood splice plates might be easier to pull off in place. Your judgement call.
Didn't mean to discourage. Just don't under estimate what you are getting yourself into.
+3 on strip out all of the garbage and loose crap. Get some real work light in there so you can see what the problems are; and take small bites where you have confidence in the outcome.
Keep taking small bites until you gain confidence in the project as a whole and your abilities. Invest time first until you are committed (...or should be :? :frightened: :D :lol: ) before you invest any serious coin. The worst thing to do in your situation, IMHO, would be to rush out and drop a lot of jingle on all of the expensive, or even semi-expensive features that you envision.
$0.02
Postby mezmo » Wed Jun 26, 2013 9:39 pm
Hi Kevin,
Your welcome. Since you are new to TTs and all, I'll throw out what
I know of ‘whatever’ whenever I think something could be helpful/useful
for you. I'm not an expert, but do have experience in the subject area. If
that can help someone out, then why not share if it could potentially be useful
to others...that's one of the main benefits in a forum like this - everyone can
learn from one another.
<RE: Your Tue Jun 25, 2013 12:34 am post>
A POSTING HINT that's saved me lot of frustration:
A good posting practice [for one's own sanity] is to compose your
post as a wordprocessing document, and once done, copy it all and
paste it into the TnTTT post composing area. I usually compose the post
in Wordpad, as it's fast to get up on my laptop. The wordprocessing
approach also gives you the option of saving the post as a document in
whichever wordprocessing program you use, which can be usefull if you
have an interruption or need to 'pause' when composing it. You can always
delete the post/document from there later if you don't want to save it there
'permanently'.
I'll try to give a comment on each thing you bring up if I have any info that
could possibly help.
I understand car repair shops will PAINT just about whatever you want as long
as you have the $$$. I see you've checked out Doug Hodder's current build thread
with his self paint startingt now, http://tnttt.com/viewtopic.php?f=50&t=52665&start=180
In that front area, I see there's a good bit of rot on the 'driver's'-side corner to repair.
I meant to include in my earlier post that if you need to do any exterior siding removal
to fix the corners [only do that at the last resort if you have to do so] that doing so
on the front and rear walls would be easier to handle than the sidewalls - smaller size
and all, but that all depends on your total amount and location of damage, I guess,
in the final analysis.
I'd also remove, over just cleaning, any component that has mold and mildew on it - some of the
seat base tops look to have it. It's healthier and easier to just replace the really contaminated
items. The under frame doesn't look too bad so you could just put new plywood on that
to replace the bad. Most 'older', especially smaller TTs, usually had a table for the dinette
that was sized to fit exactly between the bench/seat bases, resting on permanent side
supports at the top of the bench/seat long edge. That combined with the top surfaces of
the seats gave you the bed platform. A futon type mattress might be useful to use for the
combined seating and bed functions. Foam slabs are often used for seat and back cushions
and then combined as the sleep surface but that isn't as comfortable as a folding continuous
one-piece cushion/mattress to me.
One of the videos mentioned using sliding doors to close off an upper full-width storage
area where the bunk bed area is now. Often just 1/4inch plywood alone is used for those
doors. And there are 'tracks' made for them that you can buy at woodworking type
stores/suppliers. It uses a simple bottom and top track. It's basically extruded aluminum,
grooved hardwood, or extruded/molded plastic that looks like a block letter capital "W" [square
bottom corners] if you look at the end of it. It's sold in various lengths and is easier to use than
making your own sliding panel track, but that's aways an option too. Here's an example:
http://www.sears.com/search=stanley%20s ... el%20track
Once you get rid of the existing bath setup, you can reposition the toilet if you want to. I
suspect you're going to have to rebuild that corner/room, in total, due to all the wood rot,
so when you rebuild that area, reposition the toilet to where you want it in the room. If
you want a sink in there, do a fold-up sink. It's a shallow sink the folds up against the wall
when not in use and is usually positioned over the toilet. It's a great idea I think. A huge
space saver, why dedicate floor space to a sink and cabinet you only very occasionally use ?
Reposition the toilet in the existing bath footprint and thus give yourself some elbow and
knee room in there, and put a self-made foldup sink above it. You can build in some upper
storage cabinets above and/or on the sides of the toilet too if you want. Here's an example of
such a setup :[From pg14 in my Album, click to enlarge.]
71384
The Tool I mentioned is probably best known as a "Multitool" or "Multi-Tool". It has its
origin [from what I read somewhere] in the oscillating saws medical people used to
remove plaster casts. It is hand-held and is basically an electric motor that oscillates its
attachment head/bit extremely fast [similar to what an oscillating/orbital hand sander
does] which is then also scntillating the clamped/bolted on tool blade/bit. They have several
available types of small saw blades, scrapers, grout remover fitting etc. They are an extremely
handy and useful tool, especially in tight spaces. One would be a godsend for what you
are starting to do. Here's a link to one that looks like the one I have:
http://www.protoolreviews.com/tools/chi ... nction/928
After reading that review I'd go for a better quaility one and If you can afford one with a quick
blade/bit change system, go for that. Several manufacturers make them, they're just more $$$.
As I recall now, the one I got was on a half-price sale and is very basic. The higher oscillating
speed and quick change features of a more expensive one would be well worth it. Check some
reviews maybe before you get one. Also, the cheap blades can wear out fast, so get those
made with harder materials. There are many suppliers of those.
There are probably about as many build/structure methods out there as there are brands
of TTs, but a low cost basic method that is widespread in use is called the 'inside out method'. With it, the wall, floor and roof frames/sections are made of smaller dimension 1x or 2x wood
framing members, oriented both vertically and horizontally, per design requirements, and some
kind of batt or foam insulation is put in the voids of that [I'd recommend foam as insulation on
your repairs - easier to install and more R-values in general.], and the interior surface is then
covered with, usually, a plywood or plywood-like panel that is fastened and glued on. The
exterior of the TT body is usually later covered with thin aluminum sheeting after all the
sections are assembled. At the edges, where all the sections come together, an outside corner
molding is usually applied over some kind of a continuous sealing 'tape'. Butyl rubber and a
[generally specific to RVs/trailers] gray putty 'tape' are the more commonly used sealing tapes.
The quality of the exterior aluminum sheeting covering's fit, and the application/installation of
the sealing tape and the molding that covers the edges and thus 'joins' the exterior aluminum sheet edges, is what determines the water-tightness of the trailer covering and corners/edges.
Maintaining this seal is an ongoing maintenance requirement, but this is never really
communicated to buyers/owners very well. Like the older house trailers and mobile homes, TTs
were/are marketed as being pretty much "maintenance free", and most new-to-the-world-of
trailers people believe that. Maintenance neglect starts out as being uninformed of what is
needed to be checked and regularly. That's why most wood framed trailers don't last or have so
much wood rot - they've never really been maintained. Poor design and building method is also
a cause, but that is often hard for an owner to remedy. Unfotrunately, leaks can occur to even the most vigilant of TT 'maintainers' if they miss a problem and thus don't catch the leak's
cause soon enough.
Before I forget about it, I would never use silicone caulk anywhere in the TT. Once on, it is next
to impossible to get it off, and it is way too much work to try to remove, and you usually
end up damaging what you are working on in an attempt to get it off. It can be removed,
grudgingly, with buying the appropriate silicone 'remover' but that is just an extra expense,
and is often not easy to find or effective and is hard work to use - in my experience. I've never
been totally satisfied with it when I have had to use it. Avoid the headache and the work it'll
later cause and just don't use it.
Back to TT construction: As most commercial TTs are built "inside out". All of the interior
cabinets, dividers, components etc. are installed on the completed floor assembly first, then
the mostly completed walls are installed and then the mostly completed ceiling/roof is
installed. The interior cabinets and components etc. are then attached to the walls and
ceiling where they need to be . Then the exterior coverings go on. Then all the openings,
doors and windows and vents etc., are installed and all of those need to be joined and sealed at the edges and wall openings. Also, the floors, walls, ceilings/roof and the other factory made
components are usually built in jigs to insure correct and consistent fit and placement and
are then all joined together to form the trailer body. Since your damage demo and repair will
probably be easiest done from the inside, just keep in mind how it was built as you go about
the work so you can formulate your approach. For example, You may need to cut some
staples/screws/nails to remove something and the multi-tool is great for that.
[TT Trivia: Generally, aircraft method constructed TTs [Using aluminum body structure and
riveted aircraft grade aluminum skins.] have their chassis-floor and the rest of the exterior
body shell completed first, then all the rest of the interior components and systems
are installed. This requires that everything, that needs to be installed, must be able to fit
through the entrance door.]
Windows: The approach to these depends on what kind of them you have. Since the TT has
so much water damage, and leaky windows - both in themselves and in their installation -
allow the water in to cause its damage, I'd take the time to reseal them, even if that'd entail
removing them and reinstalling them with new sealing tapes. Two main methods of window
installation result from how they were designed. Either screwed on through the exterior
window frame, or installed by the clamp ring method, whereby the window has two main
components, the window frame and window, which are installed from the outside, and the
clamp-ring, which acts as the interior window frame and finish, and which fits correspondingly
to the window and is screwed to it through predrilled holes, thus clamping the wall between
the two window sections. Your's look to be that type. They are generally considered more
'modern' and 'better' in-so-far as they have a cleaner appearance and there are no holes from
any exterior screws used to secure them, thus eliminating a major potential water entry point.
If you determine there is no rot around them and the seal is still good on them, maybe just a
touch-up with a non-silicone caulking sealer around them would be in good order. There are
some good marine/boat caulking-sealers you can use for that.
That PIC looks like the trailer's electical panel with circuit breakers. "Tripping' is just when it
pops/turns itself off due to an overload of some kind. If the toggle switch is positioned in the
middle beside "Trip" label, then it cut off the ciruit due to an overload of some kind. To reset,
you ususally turn it to the "off" position, then turn it back to the "On” position. Every TT
electrical panel and system has to meet the RV electrical code at the date/time of the
manufacture. There is a "Main" circuit breaker and one for each circuit that is on the panel.
A BATTERY is not necessary unless you want total self-containment away from hook-ups. If
you'll only be camping in locations with electric power available, then you really don't need one.
Just a good power cord to hook up to the site's power pole panel, and the appropriate adapter
if needed. [There are different amp rated adapters that may be needed to be used per your TT's
electrical set-up and what the site's power pole has.] It'd be best to check out the electrical and
heating-n-plumbing sections here on TnTTT for details on all of this.
As far as AC goes, most likely the TT is prewired with a dedicated circuit to where an AC would
usually be installed on the TT - at the roof vent. That is why there is a circuit breaker labeled
for that. The most common TT ACs are the roof mounted units, as you mentioned, but they
can be pricey, but do have the advantage of not taking up interior or window space. A regular
room AC [usually much cheaper] can also be used if you wanted to mount one in a window or
make a dedicated opening elsewhere for it, but then you have to deal with all the details
involved with installing that. Just remember travel width restrictions and if you'd walk into
it when camping if you go that route.
<RE: Your Tue Jun 25, 2013 10:14 am Post>
Replace part a moldy stud: Replacing just the rotted part [plus maybe an extra inch or so
to ensure you got any that may have migrated upward a bit] is a good approach. Your
thin plywood “splints” would be good attachment supports for the new wood to the existing.
Just remember to glue all such joints [its really a reinforced butt joint] together. If you use
fasteners, screws are easiest and best in my view, but not drywall screws, they’re too brittle.
The exterior screws, and even the coated or deck kinds, are the ones to use. Their little added
cost is worth it. Also, predrill the screw holes. The smaller dimension wood used in TT
construction may split otherwise - your call. The Kreg jig approach is designed to reinforce
the butt joint.
K.C.s half-lap joint recomendation is a good approach too, strong when glued. Just decide
which method is the most doable and time effective for you.
BTW, what tools do you have available to use ? Obviously, that’ll affect what you can do and
how time consuming repairs will be.
It’s nice to see you’re getting some more input now from others too. Let’s consider such to
be The Collective Power Of The TD/TTT Force...
Cheers,
Norm/mezmo
mezmo
Images: 194
Postby djdawg » Wed Jun 26, 2013 10:21 pm
Wow...thank you again Norm! Thanks to everyone again but I think I can answer for everyone that they time you take to go into detail is so much appreciated. It excites me and gets me gassed to keep on with my project and motivates me!
In no particular order...
The weather is looking good this weekend so Sunday is my day to start cleaning out. I know when the dump closes so I'll start cleaning early so I can get everything there that needs to be and have my van clear for work Monday morning...ha ha. If I can get that shower stall out, I guess I'll do that and take it to the dump. I'm eager to carefully remove the floor and wall wood to see what's damaged and what's not. I'm really curious about what's around the windows too....I will check out those tools because it sounds like they would really help with taking apart things....even if it meant it was going to get thrown away.
Norm, I apologize but I was a little lost on this paragraph:
"In that front area, I see there's a good bit of rot on the 'driver's'-side corner to repair.
in the final analysis."
From what I can see, the corners are made up of two 2 x 2's fastened side by side. On the front left corner of the trailer - are you talking about the OUTSIDE of these 2 x 2's in calling it the "drivers side"? You mentioned something how they are smaller then the sidewalls and I'm - as always - confused. Not hard to do....
Yes I saw those seat base tops...they were gross. And cracked anyway so they will surely go. The bases look pretty good as do the benchs that are built in but again....I'll look very close on Sunday. Good to know about the tracks you can buy premade! Hell yeah! Whatever can save me some time, energy and $! Did you see my idea of covering the kickplates (not sure if that's the official term for them) of all the seating areas? I'm excited about that part....
I'm going back to re read everything you wrote again and look at that sliding sink/toilet idea. So cool....btw..for anyone that's interested, the Harbor Freight version of the Kreg Jig is getting rave reviews and is cheaper. The huge plus with HF's is that it's aluminum and not plastic.
Thanks again eveyone!!!
Oh...Norm and everyone else...are the videos helping? (I know I need more light) I'm not sure if they are easier to get a guage of the condition as good as plain old still shots.
Kevin
Bellingham, WA
djdawg
Postby djdawg » Wed Jun 26, 2013 10:56 pm
You know I've never had a multi oscillating tool and these really look like the way to go! I might even be able to do the "L" cut that KC was talking about with this thing. I see that HF has a corded one that is multi speed, includes a case and has better reviews then their first generation one. Also comes with several...well, a few I guess...blades. This could work!
BTW...I've heard a lot of good things about Eternabond. What do you guys think?
Kevin
Bellingham, WA
djdawg
Postby djdawg » Thu Jun 27, 2013 12:36 am
I hate to keep talking about this Harbor Freight multi tool but the good one... the variable speed one... is on a coupon special for $30!
Kevin
Bellingham, WA
djdawg
Postby CarlLaFong » Thu Jun 27, 2013 2:18 pm
Just one, small, comment. Unless things have changed since I built them, RVs are built just like a house. Floor first, then walls and roof last. Then the interior pieces are installed
CarlLaFong
Images: 5
Postby djdawg » Thu Jun 27, 2013 8:28 pm
Ok....this could be bad. :o I tore off most of the ceiling and some of the wall....this is what I found. Check out the videos....
http://youtu.be/IvxMZOo4_1Y
http://youtu.be/sXOy7FBIwnY
I need thoughts. Keep these things in mind when sharing with me...
What I do have:
Time
Patience
Elbow grease
SOME knowledge on how to do things but haven't remodeled an RV or built a house...but I am eager to learn.
What I DON'T have:
A lot of $
I don't mind that it's a project....I don't mind how long it might take. I just don't want to be paying more $ by the time it's all said and done as opposed if I leveled the whole thing and started from scratch. Keep what I can (maybe even the aluminum?) and build it from the beginning. The thought of that seems overwhelming but maybe I can do it....
Kevin
Bellingham, WA
djdawg
Postby CarlLaFong » Thu Jun 27, 2013 9:46 pm
Looks pretty yoogly. :shock:
:shock: I would finish gutting the interior and then remove the skin. You can then assess the damage. As I stated before, the whole thing is built from cheap 2X2s. Begin removing the bad ones and replace them, one at a time. Use a pocket jig. I bet most of the wood is OK. You should be able to cut out the bad parts of the floor and replace them with new pieces of ply. If you can't hit a crossmember, just use cleats under the trailer to screw it off to.
CarlLaFong
Images: 5
Postby djdawg » Thu Jun 27, 2013 10:38 pm
Thanks Carl! So you'd suggest to proceed even with what we DO see as rot at this point?
CarlLaFong wrote:Looks pretty yoogly. :shock:
Kevin
Bellingham, WA
djdawg
