I did a little searching but didn't turn up any solid answers. I plan on having 2 circuits, both 15 amp. Going to havea microwave and a couple outlets on one, and a mini fridge and a couple more outlets on the other. Going with a 12 gauge 25 foot extension cord for shore power, and 12 gauge wire from the shore outlet to the breaker box. (Probably like 2 feet) . Then planning on 14 gauge wire to run to the outlets (a 15 foot run, and a 5 foot run) at most I may wire a light to a switch, adding another 4 to 5 feet to the 5 foot run.
first question are my gauges kosher?
Then what type of wire do I use? I see this NM and THHN. I'm confused. I'm using treated lumber if that changes anything. Do i need conduit? I'm not insulating my trailer at all. And I dont know how much I'm going to seal it past the wood screwed down. So it may see moisture in the air.
