Cheers
Paul
doug hodder wrote:I dunno Paul...maybe cuz over here, it's a normal position weld, and where you are in the Southern Hemisphere....it would be an overhead weld...trickier to do...![]()
Doug
Doug
Aussie Nomad wrote:Paul, I thought the same thing the other day when I saw Hekki's spring mount.
I was always told not to weld across a member only to weld along it.
Using the picture as an example I would only weld it top and bottom. If it needed more strength I would drill a hole in the center and "rosette" weld it.
Maybe we have been taught to build to suit our conditions. These people might have the luxury of having roads to drive on.
Ian.
Doug
PaulC wrote:Hi All, I've noticed that a lot of the trailers over there have the draw bar welded at the front of the chassis meeting point. Over here we do not weld that particular joint so as to minimise drawbar failure. Do any of the engineering gurus (Andrew) have a way to explain to me why there would be this difference. Maybe this pic of Woodbutcher's new frame will help:
Cheers
