atahoekid wrote:I am so glad to hear that you've decided to clean it up and restore it. I've been looking for a project too. Unfortunately, I have one big obstacle. If I find one, I have no where to restore it. My driveway needs to stay clear, since I can't park on the street, my garage isn't big enough and I can't get something like that to my back yard. Good Luck on it and I will be looking on in envy. Cheers!
Gage wrote:I might add that to do it right it's going to take some time so don't get in a hurry and set a finish date and then start taking short cuts to meet that date. And it's all right to step away from it for a few weeks at a time if you don't think you’re getting anywhere. You've gotten some good advice from those that know. So take notes and run with it. And don't be afraid to ask one of us a question or two.
I agree. My biggest concern is I have ZERO experience in sheet metals (or any metals for that matter.) All of my experience is in Wood, Foam, Fiberglass and Resins. My first thought was just to make it fiberglass, but after seeing how AMAZING Rob's build is, I want to keep it as original as possible.
48Rob wrote:I agree. My biggest concern is I have ZERO experience in sheet metals (or any metals for that matter.) All of my experience is in Wood, Foam, Fiberglass and Resins. My first thought was just to make it fiberglass, but after seeing how AMAZING Rob's build is, I want to keep it as original as possible.
You'll be glad to know; there is no complicated metal work involved!
All the siding is simple flat sheets screwed together. The roof panels are flat sheets rivited together, and attached to the roof framing with some nails and screws.
Polishing is quite a chore, but not complicated.
Rob
cryptojones wrote:Is that the original metal on your restore? It looks SOOOO shiney. There are pretty big gashes in mine. I wonder if it would be worth it to just take the pieces in to a metal shop and get new ones cut.
dmb90260 wrote:cryptojones wrote:Is that the original metal on your restore? It looks SOOOO shiney. There are pretty big gashes in mine. I wonder if it would be worth it to just take the pieces in to a metal shop and get new ones cut.
If you are going that route I believe you can find metal siding that is "pre-polished" Naturally it will carry a premium price too.
48Rob wrote:Yes, it is the original aluminum.
It has some dings and deep scratches in it, that are visible, but I was going for original exterior.
New metal would be really nice if you can afford it, though the old windows and trim might look bad against the new, and before you know it, you'll have a fortune in it.
If you have shops locally that will polish the siding for you inexpensively, that would be the route to go.
I'm capable, but I'll never polish another one, it is just too much effort.
Rob
