absolutsnwbrdr wrote:The mounting points are all based off of the compressed and extended length of the struts. So I got on McMaster-Carr and looked at what they had and just started laying out my options. After about 15 combinations of mounting points, I found the best ones and then had to decide on strength. Took a wild guess and got the 120lb struts.
Yup. 120lbs. Two of them. And 4 mounting plates, and 4 ball sockets for the struts.
Wolfgang92025 wrote:Joe,
I can't help you with pick the right struts, but I found Mc Master Carr to be a real good source.
And best part is, if they don't work you just send them back for a full refund.
No questions asked, and the service for me has always been first rate.
By the way, mine are 120# and are just a touch to weak. I need a stick to help keep the hatch up.
Kharn wrote:Your strut geometry and hatch weight both factor into what force level you need to hold the hatch open. A few inches different in strut anchor locations can greatly change the force required to hold the hatch open. Ideally, the strut would be positioned such that there is a neutral point a few inches from closing at which the strut is at the most fully compressed point throughout the range of motion of the hatch. That would mean you have to work (in a properly designed system, very slightly) against the strut to open the hatch, plus that below the neutral point, the hatch would close and hold itself closed without needing to be latched (so you would not get hit in the jaw as soon as you unlock it). Above the neutral point, the hatch would open itself. But, without playing around for hours in CAD software, that can be very hard to achieve.
You could try repositioning the strut so it is more vertical, with the wall anchor point further away from the hinge. Also, the vast majority of struts are designed to have the body above the rod, so the oil inside the strut lubricates the seal and prevents the compressed gas from escaping. If you're still not successful, see my post here for a way to make the hatch lock open: Easy way to lock a hatch in the up position with gas shocks.
Junkboy999 wrote:Looking great,
Glad to hear you stayed dry at the hanggliding event. Ya I bet those people in the tents were calling you names. I just read back in your log again and was just wonder if you treaded the bottom edge of the side wall plywood with anything besides paint? With the woodworker gene in your blood I’m sure you did, but just checking.
Have a happy fourth.
Users browsing this forum: azgreg and 19 guests
