All the Best,
Dave
S. Heisley wrote:That teardrop sure is a beauty, Dave. It looks so good, it makes the rough Wild West look even rougher!![]()
Glad you had a fun time. Thanks for sharing the pics.
pelonmelon wrote:Hi Dave,
Wow! I've been lurking and following your build since day one and have to say it is as much a work of art as it is a teardrop trailer.Bravo, what an inspiration, you set the bar very high! My question though is about your tow vehicle. I have a 2009 Honda CRV AWD which I think has the same drivetrain as your Element. How does your vehicle handle the Travelear? Hills? MPG when towing? I hope to see your rig in person someday.
Thanks in advance!
Earl
My axle is 56" and the width of the trailer body is 57". The axle shafts extend enough to move the cranks out for clearance. I did go with regular non-offset wheels. Everything clears perfectly with plenty of room. The axle is a 2,000 pound axle. My buddy who built the chassis forgot to add the 'de-rated' to the order. I've done some research and it seems like the de-rating is on paper anyway. For this design, a 2,000 lb axle works fine
jhtitan wrote:You wouldn't have a dxf or dwg file of the profile would you? It would help me a ton with my design (I design in Solidworks so I could import that type of file)
Via wrote:Dave
I am interested in how you constructed what appear to be 3 vents, the hatch door and outlet on the tongue box. I have a tongue box with hatch to access the battery but no vents and the hatch door may have to be replaced. Is that an AC outlet for a battery tender?
Also where did you get your porch lights?
Thank you for your help.
drewh1 wrote:This is one of my favorite builds too, a real piece of art. You are some craftsman! -
Hope you don't mind but I am going to have to imitate it. Do you have any design drawings posted on the forum? I would love to get a real feel for the outline.
