Corwin C wrote:Your example shows how moving a small item can make a 70# difference in tongue weight. It sounds counter intuitive, but really it is not. Aircraft pilots make this calculation/measurement/adjustment every time they load an aircraft. While our situation isn't as critical as theirs, it is important to understand how moving items changes the balance and if you have issues, you will understand what corrective measures are necessary.
Also, when using Angib's spreadsheets, recognize that any "guesses" in the data entered makes the result a "guess" as well. Actually weighing parts and determining each CG eliminates the guesses, but at that point, you've built your trailer. It is a valuable tool, and a very good one, but realize that the real world doesn't always follow the engineering numbers exactly. Don't fret about not having the exact results that you were expecting ... quite frankly, I'm impressed that you were as close as you were.
Best wishes on your build...
les45 wrote:I just use my camping gear and luggage stored all the way forward to get my tongue weight. Folding table, EZ-up, chairs, tool box, and boxes of galley stuff add a lot of weight to the tongue while towing. I still have my coolers in back under the counter. Also, I left my axle in its stock location on my NT 5X8. My rig weighs about 1,400 lbs loaded with a tongue weight of 160 lbs. After upgrading my tires to 13" passenger car tires, it tows fine. Didn't do anything else to try to adjust tongue weight during construction.
working on it wrote:les45 wrote: I could throw in another 100lbs of weights, unseen!
citylights wrote:
Just make sure the weights are in the form of cast iron cook ware and you won't offend anyone's sensibilities!
citylights wrote:working on it wrote:les45 wrote: I could throw in another 100lbs of weights, unseen!
