FoamStream...
Re: FoamStream...
Postby swampjeep » Mon Jul 08, 2013 9:53 am
GPW, any chance a friend has a portable garage type canopy set up? or can you rent one? that would give you a covering you could work under even in the rain.
Not that you want to buy one, but HD sells them for about $200.
http://www.harborfreight.com/10-ft-x-17-ft-portable-garage-69039.html
swampjeep
Re: FoamStream...
Postby Bogo » Mon Jul 08, 2013 10:57 am
GPW wrote:KC, that’s a BIG vac eh ??? :o I was just hoping they would dissolve and go away ... in the next thousand years ... :roll: ... so far , they haven’t . :lol: :lol: :lol:
:thinking: They'll be gone after the next evac... :lol: :roll: :frightened:
Bogo
Images: 39
Re: FoamStream...
Postby GPW » Mon Jul 08, 2013 11:03 am
SJ, had I only known how rainy it would be this year , would have probably done that ... But too late now ... :oops:
Brown truck just dropped off the windows and hinges ... Yippee!!! They are small but very nice , and have Al trim rings ... not plastic ... :thumbsup: All came very well packaged and no signs of any damage ... Thanks to Frank the Bear ... 8) :thumbsup: :dancing
Bogo .... Likely so , along with everything else ... :frightened:
Re: FoamStream...
Postby GPW » Mon Jul 08, 2013 11:22 am
Placed the window on the door to see what it’s going to look like ... Looks Good to me ... just the right size ... :thumbsup:
Now these are the same size windows for the sides , and might appear to some to be quite small for that purpose , but since the FS is all about comfort and PRIVACY , I’m sure they’ll be OK... that and they’ve already been approved by “you know who” .... :lol:
Re: FoamStream...
Postby GPW » Mon Jul 08, 2013 11:37 am
Installing the windows in the sides means I have to have the inside wall finished first in that area ...so , I called a friend at the local Art supply store and got a price on some 1/32” thick chipboard ... 32” X40” @ 1.50 USD a sheet .... That’s pretty reasonable and should work perfectly ... likely , at that price , we’ll get enough to do the whole inside that way , providing a nice uniform surface to the foam , and a good base for even further “decoration” ... 8)
Everything’s quickly coming together now ... :D
Re: FoamStream...
Postby Mary C » Mon Jul 08, 2013 1:11 pm
GPW when you have a little time could you either direct me to your windows you made or take some picts of them somehow I missed the little details. Oh No it is thundering again. I think break time is over.
Thanks,
Mary C. :)
Mary C
Images: 473
Re: FoamStream...
Postby GPW » Mon Jul 08, 2013 1:52 pm
Mary, thundering here too ... again ... and I see some bad weather is headed up your way ... :o
  I believe what you want is on pages 17-18 of my album ... look at it and see if that helps ... ? If not maybe we can think of something else for you ... while it’s raining .... :rainy:
Re: FoamStream...
Postby dodgedartgt » Mon Jul 08, 2013 2:17 pm
GPW wrote: Sure would be Nice to have a big clean dry shop to work in ... 8)
Yep, SURE would! :(
Mike in FL
dodgedartgt
Re: FoamStream...
Postby GPW » Mon Jul 08, 2013 3:56 pm
Mike , looks like Chantal’s headed in your direction ... Hope it’s not too bad ... More rain ... :o
Re: FoamStream...
Postby Bogo » Mon Jul 08, 2013 4:37 pm
On the shop side of things, I'm designing my hard sided pop up so I can make and finish a bunch of SIP panels and other parts. Then go outside and glue/screw/bolt them together over a few day marathon. That way I can make the parts in the basement shop over winter, and assemble it in the spring in the barn. After the glue/screw/bolt phase the only things left to do should be string some wires, install a couple gaskets, install the bed, charge the batteries, fill the water and propane tanks, load up the gear and use. Of course I'll be real lucky if I get it that well organized. :lol:
Bogo
Images: 39
Re: FoamStream...
Postby GPW » Mon Jul 08, 2013 5:08 pm
Sounds like a Good plan !!! Much better than working outside in the summer ... :sweaty:
Re: FoamStream...
Postby GPW » Tue Jul 09, 2013 11:05 am
Had to run to the Doctor’s this AM (annual ) ... so lost a good bit of the cool hours of the morning for trailer work ... guess we’ll start fitting the window to the door , so we can get that all covered and out of the way , without having to work outside ... Once we get the door window fit , am going to make a cardboard template to cut out the other two holes in the cabin walls ... much quicker and easier that way ... despite having to make the template .. which BTW may be useful later on should we decide to add more windows in the future ... :o
Just in case somebody doesn’t know how to make a quickee’ window template .... just press the window down firmly into a piece of cardboard ... it leaves a nice mark of where the window edge is and can be easily traced around and cut out ... as will be seen in the following pics ...
Re: FoamStream...
Postby GPW » Tue Jul 09, 2013 11:17 am
Done !!! A few minutes invested and now we have a template to draw out all the window holes ... and it fits Perfectly .... Easy huh ??? :D 8) :thumbsup:
Re: FoamStream...
Postby GPW » Tue Jul 09, 2013 11:37 am
Just popped back together , squared off and marked ... Ready to go !!!
Re: FoamStream...
Postby GPW » Tue Jul 09, 2013 12:06 pm
Laid out on a centerline (door) , cut out with jigsaw and it fits !!! :D
