Grits,more work getting done
Re: OK, here goes: Grits
Postby CampsALot » Mon Jul 08, 2013 8:37 pm
Awesome job!!! :thumbsup: :thumbsup:
On the sore wrist, let the saw do the work, don't push.
It may take a little longer but the cuts are usually better.
That being said, the vibration from a saw can irritate just by holding on and steering it. :shock:
Warren
Foam Away From Home
106754106755
Start of Build Thread viewtopic.php?f=50&t=55752
New Build Thread viewtopic.php?f=55&t=56489
CampsALot
Images: 74
Postby CliffinGA » Mon Jul 08, 2013 11:22 pm
Mary I wish I was closer so could help you with it. Have you gotten windows yet? If not there is a person in Buford with some on CL all the time and there is a Camper parts/salvage in Loganville also. If all else fails you borrow my small tear to go if you want.
Cliff :thumbsup:
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby Mary C » Tue Jul 09, 2013 8:20 am
Cliff, I may have to take you up on that offer I am trying so hard to finish it it. The rain is a factor though. and we are getting a about an inch a day . I have been washing up my buckets, you need to do this once a year if you live on a farm, I put several very dirty buckets on my porch about a week ago and it is now, after last nights rain, over flowing. The times the sun comes out, you can see the wet earth turning into clouds as the humidity (steam) rises from the ground, then it rains again. I am so tired of this!!! I have to walk down to the barn about 150 feet through wet grass and that is ickie. Can't cut the grass even if my lawn mower was working, the grass can't dry enough to cut before it rains again. I am going down later to put on more glue hope it dries quickly as I have to start puttin on canvas tomorrow. I am going out now to buy batteries for my camera pick up a Rx and buy a loaf of bread and some more peanut butter.
Mary C. :)
Mary C
Images: 473
Postby GPW » Tue Jul 09, 2013 10:38 am
Mary , raining every day here too ... everything’s Damp ... we may have to resort to the old Piano trick , where you leave a light bulb (old style) burning inside the cabin to help chase away the dampness... Just an idea ... works in pianos ... :thinking:
Postby Mary C » Tue Jul 09, 2013 9:40 pm
Well, I learned a thing or two or three today about kerfing and bending foam. :shock: Tomorrow I will start over and try again. I made a mess :oops: today but.....Tomorrow is a new day. :worship: Please foam gods help me!!!!!! I will do it, one way or another :twisted:
Mary C. :)
Mary C
Images: 473
Postby Mary C » Tue Jul 09, 2013 10:14 pm
I found the batteries for my camera..........the pictures I promised
108791
109297
109298
109299
109300
109301
109307
109308
109309
109310
109311
109312
109313
109314
109315
109316
Mary C
Images: 473
Postby Mary C » Tue Jul 09, 2013 10:16 pm
I really have been working, now to put the top on. The hatch first..................
Mary C. :)
Mary C
Images: 473
Postby GPW » Wed Jul 10, 2013 5:46 am
Looking Great Mary !!! :thumbsup: 8)
Postby KCStudly » Wed Jul 10, 2013 6:44 am
I would consider putting the top on the cabin first. This will stiffen it up greatly and give you a more solid structure to fix the hatch to before locking everything into place.
Done the other way you may find that you are chasing a moving target and possibly have fit problems later.
$.02
Good progress there! :thumbsup:
Postby Mary C » Wed Jul 10, 2013 8:46 am
Well I have tried this three times and I am not happy. right now I am trying to just kerf to fit but it is not working 109308 the 1x4 is my hanger board for the hatch. note: where the stringer or rib starts it is flat for two inches then it starts the curve. it is tight curve and I have started the kerfing 1/2 inch from the hanger board for 6 inches and still it popped the foam when i tried to bend it. I tried again and the kerfing deeper and closer together and POP it did it again . I am getting so :x I will have to take it apart to saw and change the angle I am inclined to let it pop then fill it with glue and maybe GS and just call it a necessary split. Seal it the best I can for water problems and just cross my fingers. The bottom of the hatch is bending fine.
Mary C
Images: 473
Postby KCStudly » Wed Jul 10, 2013 8:55 am
Maybe make it two pieces edge beveled and glued together so that less filler is needed? Then just sand it a bit to take the corner down a little and round it over?
Postby Mary C » Wed Jul 10, 2013 9:06 am
That is basically what I am thinking I just didn't say it so great , When I get frustrated I cant talk much less type it. The biggest problem is I am layering 1/2 pieces of foam the first has got to be down tight against the wood. I am using a couple of screws, got 25 bricks ready to put on the foam to hold it down and before I could get it on POP! same place three times. I guess it is not going to bend right there, so like you said I will just glue it and sand it off and maybe the second piece will bend around . Well back to work to try again.
Mary C. :)
I have worked with the hatch several times and there is over an inch for play, it will be work!!!
Mary C
Images: 473
Postby GPW » Wed Jul 10, 2013 9:09 am
If you gently heat the outer surfaces whilst bending , they won’t break ... 190F is the goal temp.
Postby Mary C » Wed Jul 10, 2013 9:12 am
GPW I don't have any way to do that only a hair drier and the bend is six feet long and by the time i start the bend on one end the other end has cooled off.
Mary C. :)
Mary C
Images: 473
Postby GPW » Wed Jul 10, 2013 10:38 am
You could try the fabric trick .... cover the outside with an old bed sheet or something , then make the bends ... the covering will absorb the tension loads ... no cracking ... just bend it slowly ... :thinking:
