Sleepin Around, New Zealand.
Postby Sheddie » Tue Jul 09, 2013 5:22 pm
I think I finally found how the photo thing works.
Fingers crossed.
Sheddie.
Sheddie
Images: 1129
Re: Sleepin Around, New Zealand.
Postby Sheddie » Tue Jul 09, 2013 5:29 pm
Lets try that again.
It worked. Image
Sheddie
Images: 1129
Postby TPMcGinty » Tue Jul 09, 2013 6:41 pm
Wow! Beautiful! And I don't mean just the mountains in the background.
Tim
TPMcGinty
Images: 146
Postby pchast » Tue Jul 09, 2013 7:41 pm
Nice rig. But you may have a problem. It looks like
your front end is lifted a little.If its not normal it
can reduce your braking ability and may make
steering a little loose?
Is there anything 'extra' in your trunk that you can move?
:thinking:
Or can the trailer hitch weight be reduced a tiny bit?
:NC
pchast
Images: 97
Postby Junkboy999 » Tue Jul 09, 2013 10:17 pm
That is nice looking.
I’m sure they will catch on in the future.
Junkboy999
Images: 52
Postby Sheddie » Thu Jul 11, 2013 10:38 pm
Hi Guys,
Thanks for the comments.
Re the angle of the car. It is actually quite level. The rear wheel arch is quite low cut compared to the front, and with the long rear overhang, gives the impression of it sagging at the back. Unloaded the car still sits at its factory spec height. I am always quite conscious of what I put in the boot, and we only have about 50 kg on the tow bar. So it has not been pulled down much at all. The TD tows like a dream and even at around 60 mph you often hardly know it is there.
Regards Sheddie.
Sheddie
Images: 1129
