Building a TD with 1/2 inch thick walls. A mistake?
Postby corvusallen » Thu Jul 18, 2013 4:31 pm
I've started on my teardrop. So far it is going well, and I like the design I made.
Here are some images of it so far:
I've run into a problem. I bought 1/2 inch plywood because they were out of oversized birch in that thickness. I'm having trouble finding hinges/seals for the door and hatch. Seems like everything I find is made for 3/4 inch ply.
Does anyone know of a solution for this problem? I considered lining the doors with strips of 3/4 inch metal, or putting some kind of 1/4 inch wood paneling on the whole inside.
corvusallen
Re: Building a TD with 1/2 inch thick walls. A mistake?
Postby Roo Dog » Thu Jul 18, 2013 5:40 pm
Corv,
We used external hinges and flat seals as the door(s) are external mating.
RD
100_1738 (500x333).jpg (210.41 KiB) Viewed 683 times
100_1737 (800x533) (500x333).jpg (126.34 KiB) Viewed 683 times
Lets do a three sixty and get out of here !
Roo Dog
Postby Gage » Thu Jul 18, 2013 5:47 pm
corvusallen wrote:Does anyone know of a solution for this problem? I considered lining the doors with strips of 3/4 inch metal, or putting some kind of 1/4 inch wood paneling on the whole inside.
What I did was frame it with 3/4" pine 1"x2"s and then insolate it with 3/4' hard foam, then add interior wall of 1/8" birch.
Image Image Image
Gage
Images: 28
