What I did on Spring Break....or how to make sawdust
Postby sunny16 » Mon Apr 17, 2006 10:58 am
Had a long weekend because of Spring Break. So, since it was warm for a couple of the days I worked on the trailer! I finished up the side walls, insulated them and stained them and then attached them to the floor frame.
I also added a few roof spars which was fun. I framed the vent location.
Now I need to get more 1/8" plywood to get the inside ceiling in. Just a side note, the styrofoam insulation, the white stuff, is a pain to work with. Little white balls of foam all over the garage. I will use the pink or blue stuff in the roof.... :?
I cut it three times and it's still too short!!
Perfection is all I ask.......
sunny16
Images: 70
Postby Ira » Mon Apr 17, 2006 11:06 am
Looks really fantastic, man!
Did you use the 3/4" insulation with the silver backing? I'm STILL picking little pieces of that out of my a**!
One more thing:
What do you have planned for the front? A large window?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby sunny16 » Mon Apr 17, 2006 11:26 am
That's for the large AC unit, like at the motels! :lol: Just kidding!. I have a 18w x 14h fixed window that I have to incorporate. So I left those spars out while I figure out how to mount it. I wanted a small window so as to be able to look out the front.
sunny16
Images: 70
Postby Ira » Mon Apr 17, 2006 11:47 am
REALLY looks good! What did you use for spars? 2 by 4's? I ask because of the vent framing.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Classic Finn » Mon Apr 17, 2006 12:32 pm
Hey there! That is a nice lookin lil teardrop... I like the window shape too.
Very Nice!! :thumbsup:
Classic Finn :applause:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby sunny16 » Mon Apr 17, 2006 12:33 pm
After all the reading about spars here I was going to double up 1 x 2's. After I bought a couple and saw how they would fit I decided to use only one per location. I think it will be strong enough. I will douple them up 1 1/2 x 1 1/2 at the hatch hinge point and where I will attach my roof rack I want to use. I don't plan on sitting on top of the trailer so beefing them up isn't an issue. That's the plan at this point. I think I might have overbuilt a bit but I have the roof spars spaced about 8 inches apart. It just worked out that way with the cures and radii where they are. Thanks for the kudos.
sunny16
Images: 70
Postby bledsoe3 » Mon Apr 17, 2006 12:38 pm
Sunny, Ira asks because of mounting the vent. Read this: http://www.mikenchell.com/faq/index.php ... artlang=en
bledsoe3
Images: 112
Postby Ira » Mon Apr 17, 2006 1:27 pm
bledsoe3 wrote:Sunny, Ira asks because of mounting the vent. Read this: http://www.mikenchell.com/faq/index.php ... artlang=en
Yep, you nailed it.
Sunny, it just has to do with having actual lumber to screw into when installing the vent, screwing into the holes of your flange. Your framing/opening there may be the perfect size, 14 1/4" all around, but if you're using 1 by 2s, you need extra lumber outside of that to have something to actually screw into.
Otherwise, you'll just be screwing the vent into the skins, not into any framing.
God bless the gal that told me this BEFORE I skinned. It would have been a nightmare skinning and discovering this problem later!
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby bledsoe3 » Mon Apr 17, 2006 1:46 pm
Ira was the one who warned me. Now it is part of the FAQ section above.
bledsoe3
Images: 112
Postby sunny16 » Mon Apr 17, 2006 2:06 pm
OK, now I understand the question Ira asked. The FAQ says 1 1/2" thick material. It should probably read "wide" since a 1 x 2 is 1 1/2" thick and 3/4" wide standing up. I know it's a technicality (sp) but I figured I would get the fan (Fantastic Fan) before I skin it. Another old trailer I have only has a small steel tube frame to screw the fan to it. But thanks for the info. I would hate to find out too late. :cry:
sunny16
Images: 70
Postby Ira » Mon Apr 17, 2006 2:44 pm
I never saw this issue in FAQ--maybe I should visit that thread more often--but you got it down pat now.
It's just a matter of taking some additional 1 by 2 sticks and placing them on the outside perimeter of your opening, giving you that extra 3/4" to have something to screw into.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Spadinator » Mon Apr 17, 2006 5:27 pm
Looks good Sunny!!!!! You and I had the same idea for the long weekend!!!!!
Never do anything you don't want to explain to the paramedics.
Spadinator
Images: 47
Postby Finntec » Mon Apr 17, 2006 8:11 pm
Very nice. I like the shape. I think I will build one similar next time to go along with a Honda Element if I get one. Keep the pics coming.
Former owner of a '05 Homebuilt TD & '87 Scamp
2012 Home built 10' Teardrop.
Finntec
Images: 28
