KCStudly wrote:Hatch strength comes from the ribs and superstructure. The deeper the ribs and the more solidly the frame is built (tight fitting joints and gusseting) the more stable the shape will be. The structure is what holds the ply into it's unnatural bent position. The rigidity comes from the framework and curvature, not so much from the thickness of the ply.
I will shout it from the mountain tops. I believe in deep hatch ribs. 3 inch deep ribs are quadruple the strength of 1.5 inch deep ribs.
eamarquardt wrote:
Actually, I think laminating the rib was easier than cutting a bunch of pieces out of plywood and gluing them all together. In addition, the only wasted material was that which was lost from the saw kerfs. Minimal. Also I really like the side view of all the laminations.
Just my two cents.
Cheers,
Gus
