by Arne » Thu May 04, 2006 5:35 am
I doubt cpes will mess up your stain once the stain is dry. However, once you put cpes on, I doubt you will be able to restain the piece as stain should not absorb through the cpes (which is really a very thin resin). So, if you get sun fade, I'm not sure what you would do to refinish it....
You could call rot doc and talk to them about it. My take is, once you put cpes on, you got what you got....
