Where to get aluminum nails?
Postby Oregon Brew » Wed Jul 31, 2013 8:42 am
Where can I get aluminum nails, and are those the best way to attach the galley wall cap/door opening cap edge molding from Lil Bear? (see:
http://www.lilbear.teardrops.net/parts.html#hinge
These moldings don't have screw holes, so I'm wondering the best way to attach them to plywood. Thanks!
Oregon Brew
Re: Where to get aluminum nails?
Postby H.A. » Wed Jul 31, 2013 1:03 pm
H.A.
Postby aggie79 » Wed Jul 31, 2013 5:34 pm
OB,
I used 1-1/4" screw nails. They are steel with some sort of silver finish. I've not had any issues with rust or corrosion due to dissimilar metals. Here's a link to what I used.
http://www.homedepot.com/p/MD-Building-Products-1-1-4-in-Silver-Carbon-Steel-Floor-Screw-Nails-1-lb-Pack-95638/100159731
I first adhered the trim with sealant/adhesive. I used 3M 4200. The trim was temporarily held in place with shallow screws. After the adhesive set, I removed the screws, squirted some of the sealant in the screw holes, and hammered in the screw nails.
I don't have any real good pictures, but you can get any idea in these two. The first is along my door trim. You can see the screw nails above and below the latch. You can also see some of the sealant oozing out. I cleaned it later. In the second picture, you can see them on the wall cap trim installed on the galley sidewalls.
Take care,
Postby TPMcGinty » Thu Aug 01, 2013 6:47 am
I bought these at Menards:
http://www.menardsonlinecollections.com/main/tools-hardware/fasteners/nails/roofing/1-1-4-aluminum-cedar-shingle-nail/p-1495014-c-8770.htm
I liked them because the twist helped hold them in place better. Any big box home improvement store should have some.
Tim
TPMcGinty
Images: 146
