Source for Scotty Trailer Design Plans?
Postby dmckruit » Fri Aug 02, 2013 11:43 am
Does anybody know where I can find design plans for a Scotty Trailer? Specifically the trailer frame first, then utimately dimensions for the body of a mid "70's type Highlander. I know I can probably buy a old one to restore, but most of them are expensive as is and you usually have to rebuild them up from the ground anyway. So as an alternative option, I am weighing the idea of just building one from scratch.
Any thoughts or sources of information would be welcome.
Dave
dmckruit
Images: 212
Re: Source for Scotty Trailer Design Plans?
Postby angib » Fri Aug 02, 2013 12:34 pm
I have the following 2-D drawings that are reasonably close to a (late-60s?) Highlander.
However I should stress I have nothing more and certainly not a frame design.
angib
5000 Club
5000 Club
Images: 231
Postby bobhenry » Fri Aug 02, 2013 1:14 pm
Here is the naked frame...............
Postby angib » Fri Aug 02, 2013 3:18 pm
Well thanks for that - I had wondered what the central tongue member connected to..... and the answer is pretty much nothing!
angib
5000 Club
5000 Club
Images: 231
Postby doug hodder » Sat Aug 03, 2013 9:08 am
I cloned a '65 Serro Scotty, pretty much a shorter version of the Highlander. I copied the dimensions of a buddies frame that he was restoring. Here's what I built for a frame. Doug
Postby dmckruit » Sat Aug 03, 2013 11:14 am
Thanks for all the responses. Does anybody have the dimensions for the frame?
dmckruit
Images: 212
Postby doug hodder » Sat Aug 03, 2013 8:23 pm
I checked my file on the Nomad. Somehow the scale drawing isn't there, as it was larger than 8.5 x 11. I'm old school, actually draft mine up using a T square and pencil. I'll dig a bit and see what I can find. What size are you wanting to build...Highlander or Serro Scotty? Doug
Postby goldcoop » Sun Aug 04, 2013 11:12 am
dmckruit wrote:Thanks for all the responses. Does anybody have the dimensions for the frame?
Dave-
How close are you to Bedford?
My friend Rose has a few Scottie's you could look at for dimensions, etc.
Cheers,
Coop
goldcoop
Images: 32
Postby jonw » Sun Aug 04, 2013 12:36 pm
Check with Nancy Kroes at http://www.nationalserroscotty.org/ - if anyone would have plans she/they would.
jonw
Titanium Donating Member
Images: 163
Postby dmckruit » Sun Aug 04, 2013 8:02 pm
Dave-
Cheers,
Coop
Coop,
I'm about 2 hours from Bedford. However, I do work with a guy whose family still lives there. I looked at a 13' one in New Stanton last week. It was a rubble of a heap but the frame still looked okay. $50 for all. Too small for what i was looking for, plus i would have had to tear it down to haul it away. I want a highlander on the cheap.
I guess i will be seeing you in a couple weeks at Cooks Forest!
Dave
dmckruit
Images: 212
Postby dano » Thu Jul 31, 2014 12:55 pm
hi , I'm also thinking about trying to build a Serro Scotty. Did anyone ever find any frame dementions ? I sure would love to have them if someone has them. I cant find any serro ,s in good enough shape so I may give it a try :shock:
Dano
[email protected]
Morgan Hill Ca.
dano
Postby len19070 » Thu Jul 31, 2014 4:44 pm
I have one for Sale?
Some assembly required!
Now.
Happy Trails
Len
len19070
Images: 24
Postby dano » Thu Jul 31, 2014 5:55 pm
Len, that's funny but I would love if you took a tape to that frame and gave me some measurement's. I'm looking for the length of the side and middle tubes and the width if available. I'm thinking about a serro scotty like the scotty your building . However I know I wont be able to do as great of a job as you. :)
Dano
[email protected]
Morgan Hill Ca.
dano
Postby dano » Fri Oct 31, 2014 9:28 pm
Anyone?
I got the measurements for the frame but need the distance from cross member to cross member.
Thanks
Dan
[email protected]
Morgan Hill Ca.
dano
