Revised list 131 trailers' size & weight pg 1 - graph pg 8
Re: Please post your completed trailer's size/weight
Postby S. Heisley » Thu Aug 01, 2013 8:57 pm
Thanks for all the input, people. :) Please keep replying with your trailer sizes and weight. I will let them accumulate for about a week before I update the document. I may give it a couple weeks before I calculate the averages, etc, as that will give people, who might be on vacation, an opportunity to add theirs in.
Postby Wolffarmer » Thu Aug 01, 2013 9:35 pm
4x8 plywood, insulated, lots of oak and maple. Weighed it ready to go camping. Without the camping gear I will say 1000 lbs. A little on the heavy side. Also it is built to go on rough roads and some light 4x4. Also the spare tire is in there.
Randy
Wolffarmer
Images: 309
Postby Donutboy » Thu Aug 01, 2013 10:28 pm
Here's the stats on Steve Wolverton's Puffin, which mine is loosely copied from. (I don't think he posts on here anymore):
Posted: Wed Jun 06, 2007 12:53 pm
Post subject: I weighed the Puffin today. 796 pounds fully loaded ready to roll.
I estimated it would weigh 700 pounds, so I missed it by 100. I don't think I included the AC, 13" television, or 3/4"
plywood dropped floor in the original calculations. I have 156 pounds of tongue weight. I'm probably going to remove
the huge box on the tongue and replace it with a small one to hold my extension cords and stuff. I'll start hauling the
items I have in the box under the bed when I get the rear hatch installed.
So, a hair under 800 pounds.
From an earlier response in the same thread:
The camper is 96" long and 72.5" wide.
Again, that is for Steve's camper, not mine. I will get mine weighed as soon as I get it completed.
Update: I went back and looked at the original thread. To get this light weight, he used a Harbor Freight trailer, 1/2" ply for the floor, 1/4" ply for the sides, front/roof/back. No insulation. The cabinets have a front face but no doors. I suspect mine will weigh at least a couple of hundred pounds more.
Jerry
Retro-Kamper
(Puffin for Four)
Donutboy
Images: 126
Postby S. Heisley » Fri Aug 02, 2013 3:33 pm
Wow! Puffin statistics? Thanks for that, Jerry. I wonder how Steve was able to build it so lightweight?!
Of course, this is exactly what I said earlier. When you see that someone was able to build so light, it makes you want to go to their build site and find out! So, this thread will encourage people to do just that and...excuse the pun..."enlighten" themselves. :roll:
Postby S. Heisley » Fri Aug 02, 2013 3:40 pm
Thanks, all....
Don't let the PC keys stop you now! People, please keep those measurements and weights coming! :thumbs up1:
Postby Dean in Ct. » Fri Aug 02, 2013 3:52 pm
Mine is 4 1/2' x 10' and weighs 1250# It is 1/2" ply with 1" foam on the inside and a paper bag and Elmer"s interior finish. I have a 10 gallon water tank that I am going to do away with. White pine and luan cabinetry. Started with a fairly heavy boat trailer.
Dean in Ct.
Images: 32
Postby jonw » Fri Aug 02, 2013 5:40 pm
5ft wide by 8ft long (not incl. 42in. tongue). Weighs 720lbs with memory foam mattress and loaded minus food.
Built using marine plywood and no frame. See build journal for details...
109460
jonw
Titanium Donating Member
Images: 163
Postby emiller » Fri Aug 02, 2013 6:37 pm
Teardrop 5 x 9 1500# ply
45 Bread loaf 6 x 12 1400# alu
emiller
Images: 157
Postby S. Heisley » Fri Aug 02, 2013 8:52 pm
Adding the :pictures: of the trailers that you have makes this thread even more interesting than giving weight and size alone;
so, Double thanks for that! :D
:o What fun!
Postby doug hodder » Fri Aug 02, 2013 9:09 pm
Sharon...These 2 aren't in the list when it was first compiled.
4'6" x 10'6" tear .....1100# plywood and epoxy
Standy 6'7" x 10'9" 1425# ply walls with alum. skin .025
Postby S. Heisley » Fri Aug 02, 2013 9:25 pm
Thanks, Doug. You're gonna have another one to add pretty soon! ;)
Postby Donutboy » Fri Aug 02, 2013 9:40 pm
S. Heisley wrote:Wow! Puffin statistics? Thanks for that, Jerry. I wonder how Steve was able to build it so lightweight?!
I edited my post with some additional info from Steve's original build thread, for anyone interested.
Jerry
Jerry
Retro-Kamper
(Puffin for Four)
Donutboy
Images: 126
Postby Arne » Fri Aug 02, 2013 10:08 pm
5' x 9'. ply, 1,200#
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Backroads4me » Sat Aug 03, 2013 12:30 am
5 X 9, plywood---1,000# as per the manufacturer's information.
Deb
Backroads4me
Postby Larry C » Sat Aug 03, 2013 7:41 am
Sharon,
This is a great thread :thumbsup: I hope it keeps going. An interesting addition would be the approx. build cost.
"If its worth doing it's worth doing Light"
http://www.tnttt.com/viewtopic.php?f=50&t=35852
Larry C
Images: 78
