I did a dry (wet) run on the sink, it works, but unless you have the faucet on all the way it pulsates, so I ordered an accumulator tank, as well as some right angle fittings for the pump so it will fit closer to the wall (they seem proprietary). im going to have the pump and the tank (about the same size as the pump) right below the sink in the corner next to the drain.
theres going to be a small box on the front above the tounge to hold 2 of those blue tanks, the one there is for the drain, the other will be for fresh water.
once the parts I ordered get here I can mount the pump and accumulator tank, then I need some more lumber, plywood for the front of the trailer, and some 2x2's so I can build/attach the box for the water tanks, but after spending $70 on the accumulator tank, fittings, and the shore power outlet, I gotta wait a little to buy the lumber. maybe I can save enough money, and santa can help me get the last few things I need to finish this beast. im not planning on camping anymore this year, so no rush, but I plan on having it done sometime in spring next year at the latest.
oh and yes for anyone that notices that is electrical conduit used for the plumping, I reiterate that im broke, my dad had some spare, and I googled it, and while I doubt it would pass building codes, its made of the same type of pvc with just some gray dye added. I figure since its just for drain water no biggie. I plan on painting it white.
