Prem wrote:Instant (and inexpensive) tiny travel trailer.
Not as cute as a teardrop but prob is a lot cheaper with lots of possibilities. Sure would get you off the ground and keep you dry.
Earnest
lrrowe wrote:Prem,
I looked up the Bravo trailer you posted. The company and trailers look interesting. I am headed north to PA (am in SW Virginia) to look at two other manufacturers soon. But if I do not see anything I like (because of the many posts here, I am learning to check out trailers for quality work and materials), I will head down to NC to their nearest dealers to check Bravo out. Thanks for the post.
Bob
crumvoc wrote:lrrowe wrote:Prem,
Bob
I like that idea of the rear door on the Bravo trailer. Been thinking about doing a mockup by taking off my barn doors and inserting into the hole a lightweight wood framed temporary wall with an old RV door to test the concept. One "advantage" is that one could use the forward (passenger side) cargo door to access underbed storage... another idea I'm flirting with is to change my set up from a rear bed to a front bed. That way, if I keep the barn doors, I can roll in the motorcycle and still keep much of the bed in place, whereas now I have to completely disassemble it. maybe try to figure out a way to put an RV latch on the left (driver side) barn door?
