Smoky Mountain Camper
Postby volster » Sun Aug 04, 2013 11:19 am
Here are some pictures of my starting point. I picked up this 1974 AMF Skamper off of craigslist for $100. I am going to strip it to the frame and start from scratch. I have had thoughts of removing one axle and cutting the frame to make it smaller, I just don't want to pull that much. The tag on the side says it has 5000GVW and two 3350lb axles. Trying to decide on a 18'X7.5' or a 14'X7' trailer.
volster
Re: Smoky Mountain Camper
Postby volster » Sun Aug 04, 2013 11:20 am
interior
volster
Postby volster » Sun Aug 04, 2013 11:22 am
interior 2
volster
Postby volster » Sun Aug 04, 2013 11:23 am
interior 3
volster
interior 4
volster
Postby volster » Thu Aug 08, 2013 3:11 pm
Spent some time gutting the inside today, this might take a while. There is a lot of neat old trim pieces and so forth that I might be able to reuse. This will not be a fast build, but it will be quality. I am thinking about cutting the frame to be between 14’ and 16’ with a width of 7’. I am also going to see if I can remove an axle without removing the suspension. :thinking: I will be able to check this when I get to bare frame.
volster
Postby rebapuck » Fri Aug 16, 2013 10:57 pm
That looks right roomy. Save everything. You can dispose of stuff when you are finished. Unless you want to save it for the next one.
Judy
1966 VW camper
1967 VW singlecab
rebapuck
Postby 225 » Fri Aug 16, 2013 11:24 pm
Where are you located?
Postby volster » Mon Aug 19, 2013 9:30 am
I have been saving stuff, but am running out of room. I did sell the scrap aluminum for $55, so my investment is $45 now (plus time). I am thinking about turning this one into a teardrop/breadloaf or tear-loaf. I am thinking about doing a slide-in teardrop box for my 6'6" X 10" trailer so I can use both the trailer and camper, having a rear door kind of like the airstream basecamp. I am in Maryville, TN in the foothills of the Great Smoky Mountain National Park. I will start new threads for both projects since they have both changed from original conception to what I have on paper now. Thanks for all the help from everyone on here.
volster
Postby coop74 » Mon Aug 19, 2013 10:37 am
I live in Alcoa. Other then that one week a year we should get together. Let me know if you need a hand with your builds. You might want to look at mine if you want one that works as a sleeper or a hauler...
Robert "Coop" Cooper
coop74
Postby volster » Mon Aug 19, 2013 11:53 am
Sent you a PM Coop. Go Rebels. ;)
volster
