Larry C wrote:Sharon,
This is a great threadI hope it keeps going. An interesting addition would be the approx. build cost.
KCStudly wrote:Another thing about cost that I am suspicious about is if someone does not keep very close track, they might just tend to add up the big ticket items in their head and forget all of the small stuff that makes a big difference in the total cost.
bc toys wrote:6x19 cargo dry # 1000 and waiting on it to get here![]()
myoung wrote:Enjoy the build. For similar reasons, I too chose the Compact design, but made quite a few modifications to design and layout and size. As a point of reference, my 6x11x5.5 trailer weighs 1,450 with a full propane tank, half water tank, and full port-potti.
slowcowboy wrote:I don't think I could even come up with a cost of my teardrop. I can't even remmber all the dry wall sqrews I bought and hand sqrewed in with a screw driver! I bought it all over a peroid of 4 years. some of it was found in a local land fill some of it was stuff I had on hand already some came of ebay and some out of hardware stores such as ace and some from lumber stores and some from harbor freight. some was a parts from a old pop up trailer I bought and tore apart for parts.
I don't think I could really come up with a cost to my teardrop I didn't save any recipets or write nothing down.
slow
S. Heisley wrote:alaska teardrop wrote:Sharon, you've taken on quite a worthwhile & useful project.
But hey, what about us folks that build with metal?
Alaska Teardrops - 880# (4x8) Aluminum over steel tube.
Northern Lite Traveler - 525# (4x7) Aluminum over aluminum tube.
Stacie's Glampette - 554# (4x6) Aluminum over steel & aluminum tube.
I thought about that but it's hard to separate those out, as these types have been considered and lumped into "traditional" building styles for quite a while. It would be especially difficult to do that as these statistics started 5 years ago, back in 2008, and some of these builders don't log on very often any more. Most aluminum clad trailers still have traditional framing and plywood or plywood-like interior walls and ceilings. Some have 1/8" plywood under the aluminum; others, do not. In thinking about the aluminum, I had to consider and rationalize that the weight of a 4x8' sheet of aluminum was probably close enough to the weight of 1/8" plywood.Under the circumstances, I really had little choice.
Also, please recognize that the weight of a trailer is mostly in the hands of the builder, regardless of what materials are used. There will be some who will over-build, totally, with 2x4 lumber and some, who build like you do. Some will build with oak or walnut and others, with poplar. Rookies, in particular, tend to think that they are building a house and put supporting boards or spars every 16 or 18 inches, or even closer, instead of framing sparingly. Each choice makes a difference; but, over-all, the averages that we come up with will give people an idea of what to expect; and, if they want to look at the weight of a specific trailer, the forum member's name will give them enough information to pursue more knowledge. The same may be found true with foamies. Although only a few foamie owners have come forward, so far, one can already see that there can be wide differences in weight, dependent upon the builder's style and even the trailer style. By looking at the entire resulting document, people will be able to conclude accordingly.
For those builders who sell trailers, this may be looked upon as a type of advertisement. People looking for a very light trailer may look at this document and contact you to ask how you were able to build it so light. That just might be your lead into selling them a trailer. ...One never knows.
Thanks for your input.
