Thanks, GPW, Ryan and RandyG. I appreciate the kind words. Yes, the weather has been good. I just need to stop thinking of it as “good sleeping weather” and start thinking of it as “good building weather”! Need to get going sooner in the day.
We’ve all said it before, “I didn’t get as much done today as I thought I would”.
First, I slept in all morning. Wish I could do that every Monday!
I stopped at the Ho-de-po for a few small things, including some temporary bolts to attach the floor to the build cradle.
Next, I went and had an authentic Philly cheese steak sandwich from a small joint hidden in the back streets of Norwich that I had heard of thru word of mouth. I don’t think I have ever had an authentic PCS, at least not one that was soaked with Cheese-Whiz and falling apart as I bit into it, but that is what everyone says they are like, so I guess it was the real deal!
Then finally out to Mecca.
The first task should have been simple, quick and easy; bolting the floor to the build cradle. It didn’t go that way.
I spent several minutes measuring and positioning the floor over the cradle. Because the slats in the cradle are adjacent to the vertical blocking in the cradle, and because I had screwed the cradle down to the saw horses directly in alignment with the blocking (for load transfer/strength), I couldn’t just crawl under and look up to see if the holes were aligned. The horses were in the way, so I just measured and centered the floor up to the cradle.
Well, the bolts didn’t find the holes, so I had to shift the floor out of position to see what was up. Found that I had drilled the holes in the wrong locations in the cradle slats; 23 inches c/c in lieu of the required 19 inches c/c.
Karl was on the road working a job, otherwise this would have been simply a matter of moving the floor off of the cradle and drilling new holes, but I can’t safely move the floor by myself and using the hoist would have introduced a whole other set of logistics.
I had to shift the floor back and forth in order to fit the cordless drill in there to remove the screws holding the cradle to the horses (better to find that out now), so that I could shift the cradle back and forth on the saw horses, so that I could drill up thru the slats from the bottom. Also, had to space the floor up on foam scraps to prevent running the drill up into the floor (nearly tipped over one of the horses while I was under there moving things around). The whole time I’m up and down, moving around on the floor with a mover’s blanket, and a smaller fan trying to keep cool.
Laid out the new holes from the underside, drilled them, and repositioned the floor again so that it was all centered up. Now 3 out of 4 holes lined up.
The temporary bolts needed to be longer than the final ones (the slats are 3/4 thk whereas the trailer frame xmbrs are only 1/8 thk). I was able to buy 2 inch long and 2-1/2 inch long bolts, but needed 2-1/4 long; had to cut the bolts to length on the cut off saw and re-bevel on the Bader.
Once I had the 3 bolts in loose, I slipped a scrap shim of 5mm underlay in between the floor and cradle to act as a protective waster (so that I didn’t chisel up into the floor), and used the 3/8 chisel to slot the last hole in the slat to align with the hole in the floor.
Once the waster shim was out, and all of the bolts were in and tightened down, I repositioned the cradle and floor assembly back centered over the saw horses. This time I drilled and screwed up thru the bottoms of the boards (that are attached on tops of the folding steel horses) and into the bottoms of the main frame rails of the cradle. These screws are important to keep the whole deal from sliding off of the horses while I push and shove during the build.
Here is a shot looking up thru the cradle at the bolts holding the floor to it.
So installing four little bolts that should have been a slam dunk took a couple of hours.
Next I made these little temporary clamp blocks and screwed them to the side of the floor to help align and clamp the street side wall into position and hold it while installing the screws up thru the bottom of the floor.
The ones at the front and rear are close to the ends of the wall so that a std. quick clamp can reach. The one in the middle is strategically place towards the rear of the door opening, for the same reason.
A bit obsessive, I wrapped 3 more small blocks in rosin paper to go between the clamps and the finished inside of the wall.
I need to get an earlier start tomorrow!
