The Poet Creek Express - Foamie Hybrid
Re: The Poet Creek Express - Foamie Hybrid
Postby GPW » Fri Aug 16, 2013 7:02 am
Like building the sailboat in the basement ... :D KC, whatever you have to do to get the trailer done and together , rest assured that having a Nice place to build (especially a fully equipped Fab shop) is way better than building Outside ... waaaaaaaay Better !!! :thumbsup:
Still thinking you should paint it like a Pumpkin (tastefully of course... more Wyeth that Warhol) !!! 8) Safety color too !!! :thinking:
Postby KCStudly » Fri Aug 16, 2013 11:33 pm
Okay Geep, I'll make you a deal. You do the Jeanie's bottle interior and I'll think about the pumpkin paint theme! :R
Early start with great building weather. 65 deg F and 64/ct humidity to start. By the time I finished for the day it was only 81 F, but the humidity had dropped to 44/ct.
Started by clearing the saw table and bench, laying down a moving blanket and, because that was a little dirty, my dust cover sheet, to protect the finish of the curb side wall.
Ran the 1/8 inch radius bit around the outside of the door opening and the hatch switch penetration.
Did a little light sanding to dress that up and complete the edge along the bottom of the tapered sill.
Got two of the temporary blocks attached. I wasn’t sure how easy it would be to slip the wall in between these and the bulkhead so I left the middle one out to start, but during the dry fit it was obvious that adding the middle one would not be a problem.
I made sure not to run the temp block screws thru the wall mounting screw holes.
I shifted the masking on the front side of the dado forward 3/16 inch to account for the overlapping panel of the bulkhead (I had forgotten to do this on the street side and will have to pick tape out of the joint). Also, I laid out and drilled the clearance holes for the wall to bulkhead screws in the dado. Due to the hatch actuator switch location the pattern was modified to 6 inches from the bottom, 6 inches, 10 inches, then equally spaced at 8 inches on up to the top (so just the second hole from the bottom was 2 inches lower than the street side, and the rest were all the same).
I set the temporary upper angle bracket on the bulkhead, then came the dry fit.
Here is a close up of the fit where the curve of the galley side wall on the curb side comes down and meets the back of the floor. This is my key registration.
Comparing that to the street side.
They are pretty close. The street side wall is flush and turned out to be just 1/16 inch longer (only 1-5/8 from the front of the wall to the front of the floor when it should have been 1-11/16 inches). The curb side wall is about 1/32 inch shy from being exact at the rear but I couldn’t get it to shift back any further because it was locked into the dado at the bulkhead (close enough). The curb side wall appears to be at the planned length, so it sits back from the street side wall 1/32 inch at the front (again, close enough).
Street side front edge.
Can’t really see it with the clamp in the way, but this is the curb side front.
I went along and pilot drilled the screw holes up thru the underside of the floor, and into the side of the bulkhead thru the holes that I had drilled in the dado. Then I pulled the wall back down and set the depth needed to finish drilling the pilot holes to full depth. I stuck a screw up thru one of the holes in the floor, marked it with a Sharpie, then flagged the drill bit with some tape, allowing a little extra, using the tip of the screw as gauge to figure the pilot hole depth.
Then I ran that in the starter holes that I had already drilled in the bottom of the wall and edge of the bulkhead to get the full depth needed.
Chiseled a slight relief under the rear corner to account for where the rear wear edge sits under the wall (barely visible just under the tape line at the rear).
Then I laid 2 beads of PL along the base of the wall and one down in the dado, before putting the wall back in place and screwing it off. Here you can see some of the gray glue line on the inside (in between the tape) after I wiped it down.
This is looking from the front down the curb side wall at the glue joint after clean up.
Same thing looking down the street side.
Woo who, I made my goal! Walls up!!!
Mom had us up for a nice dinner to celebrate my upcoming B-day.
Orange gelatin with shredded carrot, crushed pineapple and a gorgonzola/mayo dressing; grilled marinated and butterflied leg of lamb; grilled cilantro/lime marinated chicken breast; steamed asparagus; fresh sweet corn on the cob (picked same day, boiled only 3 min.); and a cold brown rice salad with scallions, red onion, cilantro, dried apricots (?), dried cranberries, pistachios, almonds, walnuts, and perhaps an oil based dressing (very light?).
Dessert was ginger ice cream from the local dairy, with grilled fresh pineapple, fresh black raspberries that we picked before dinner, and blueberries, served with almond horn cookies and pecan sandies.
I took a lot more pictures of the food, but felt that I should be a little more conservative with the OT pics. The meal was fabulous. I really enjoyed the combinations of flavors.
Thanks, mom.
Postby S. Heisley » Sat Aug 17, 2013 12:28 am
Personally, I like this eye-candy the best!
:woohoo: MILESTONE!!! THE WALLS ARE Up!!!!
:applause: :beer: :wine: :D
Postby GPW » Sat Aug 17, 2013 5:39 am
WOW!!! Looking GREAT !!! :thumbsup: 8) :D
Funny you should call me that (Geep)... was my nickname as a kid ... now my friends call me “Doc” ...
Mixing up the Purple now , searching for purple flame velvet ... Guess we’ll have to sew up a Jeannie outfit for the trailer ... Works for me ... :lol: :lol: :lol:
Can you imagine showing up at the Chunkin’ event in a Pumpkin :o ... They’ll all be scratching their heads figuring out a way to toss it ... :frightened: Likely will get lots of Television coverage , You could become FAMOUS 8) ... Might be the start of a Lucrative new career... ya’ never know eh ? :thinking:
Postby Mary C » Sat Aug 17, 2013 12:41 pm
Yea!!!! the walls are up :applause: :applause: :applause: :applause: :applause: :applause: . Your build looks so good!!!!
And I liked the food porn, It is a welcome relief after working so hard on the TD!!!! and a pleasure to see it on here. Gives us a reason to master TD building!!!
really you are doing a great job!!!
Mary C. :wine:
Mary C
Images: 473
Postby KCStudly » Sat Aug 17, 2013 9:07 pm
Sharon, thank you so much for the over the top enthusiasm! It is well received. I really like that pic, too. :)
GPW, I'm not sure that a little pumpkin trailer would even phase anyone down there. Maybe catch an eye or two, but to get any real attention you either need to throw in the top 3 positions of your class, or do something really stupid, like be a big burly bearded biker dude dressed up in a pink tutu and wrestle a pumpkin in the mud! :lol: You know, good clean fun! :lol:
Mary, Thank you for the very kind compliments. I'm trying.
Taking a little time off this week. Would have liked to have been able to swing thru Walk the Winds on the way to Poet Creek this week, but I will get another chance next year, and I don't see any problem getting done well before this time next season. I just need to stay on it and, "get 'er done".
Thank you everyone.
Postby kudzu » Sun Aug 18, 2013 8:20 am
Can't tell you how much I love seeing this trailer coming together!
kudzu
Images: 16
Postby KCStudly » Sun Aug 18, 2013 9:03 am
Thanks, Kudzu.
This morning we had fancy french toast stuffed with ham and swiss, on a raft of asparagus over a nap of maple syrup infused with mustard seeds, accompanied by two perfectly soft poached eggs, all while sitting in the cool mountain breeze on a veranda overlooking Newfound Lake.
Honey in my coffee.
Postby RandyG » Sun Aug 18, 2013 11:08 am
Speaking of pumpkins, any new ideas for a pumpkin launcher? Or just use the same one from last year?
Randy
RandyG
Images: 115
Postby eaglesdare » Sun Aug 18, 2013 3:53 pm
Looking good! Yay for the walls up. :wine:
Oh and the food looks yummy!
Louella
May the foam be with you.
eaglesdare
Postby KCStudly » Sun Aug 18, 2013 5:20 pm
Randy, No new design this year, unfortunately. All of the team members have been busy with home life or other projects ( :NC ) and there is a lack of continuity on what we have been planning to build. Every once in a while we think we get something pinned down, but then time passes and someone will have another idea. We seem to lack consensus, and without a working model or 3D design "progress" comes in very small steps; sometimes backwards ones.
Thanks, Louella. I thought of you the other day when Yvette and I went to the Roger Williams Park Zoo and saw the Bald Eagle exhibit.
Postby eaglesdare » Sun Aug 18, 2013 8:14 pm
Thanks for thinking of me. LOL Did you take pics of the eagles?
Louella
eaglesdare
Postby wagondude » Sun Aug 18, 2013 8:30 pm
:applause: :applause: :applause: Walls up! Does that mean cabinets are next? Re: cilantro lime chicken, I grilled up some this weekend for a family gathering. Didn't have nearly as many tasty treats as you had, but I did make some corn dogs for my nieces with the waffle dogger. The shine on that finish in TPCE is going to blind someone. 8) :thumbsup:
Bill
101137
wagondude
Images: 35
Postby KCStudly » Sun Aug 18, 2013 10:23 pm
I took a few, and if you dig into the link I put up before you can see a few more.
It was very interesting because the habitat had no cage or netting, just a low wall around 3 sides and a slight moat at the front. There was a sign explaining that both the male and female came to the zoo injured and unable to fly (we only saw one when we were there). They were able to do cosmetic reconstruction on each of their wings, but the birds are, unfortunately, unable to fly. I guess that is the only way I would ever want to see one of these majestic birds in a zoo.
WD, I think I'm going to rough in some of the electrical first, then start on the cabinets, hatch and hatch actuator install. First thing will be to lower the whole assembly down (by folding the legs of the horses under the cradle) for easier access.
Thanks for the nice comments. :thumbsup:
Postby GPW » Mon Aug 19, 2013 5:50 am
Cabinets ??? :o :shock: ... It IS going to be “Furniture “ ... :thumbsup: 8) 8) 8) :D Considering what you’ve done so far , we can’t wait to see your cabinets :dancing ... I think EVERYBODY will want to closely follow along on that ... Maybe make it like a Cabinet “Tutorial" ... :thinking: Educational !!! :thumbsup: 8)
