dwgriff1 wrote:Studying Andrew's tongue data. I need to rebuild mine.
The original tears had a very short tongue, 26" comes to mind. I know from experience that the best economy pulling the trailer (with a smallish car) is with that very short tongue. But when it comes to parking and backing one of the little sweeties, 26 inches is really short (I know that one too, by experience).
How about a simple telescoping tongue?
I intend to use the single tongue design as my trailer weighs less than 600 pounds it should be more than adequate no matter where I pull it. The telescoping idea does not sound too complex, but what do I know?
dave
alaska teardrop wrote:dwgriff1 wrote:Studying Andrew's tongue data. I need to rebuild mine.
daveDave, I think Andrew has given you good advice & hope it works for you. But just for grins, how about steerable trailer wheels?
angib wrote:I have a gut feel aversion to telescoping tongues as it's so easy to make one that isn't structurally sound. I think all this use of receivers (where both the receiver and the stinger are thick wall but short tubes) gives people bad ideas!
So if you're going to have a telescoping tongue, I would like to see:
- a long, long 'receiver' section - like a couple of feet long minimum;
- no holes in the tongue at the front end of the 'receiver' - so any holes for pins well behind the front end (yes, that will make it awkward to put the pins in and out and, yes, you will have to lie in the dirt to do so);
The problem with pin holes in a telescoping tongue is that you may want some extra holes in the tongue for the 'retracted' position. No problem, as long as these are in the front half of the exposed tongue length where the tongue strength isn't too critical.
The receiver will need to be supported at least as well as a single tongue would be - so for example, welding it just to the front cross-member won't be sufficient.
Here's a sketch:
