8/5/13
OK, so I sanded the fiberglass. Not so great. I will cover it with wood filler to make it smooth. The fiberglass will keep it from leaking, but it is hard to work with. The other areas are not as important as the roof. If it leaks, it leaks. I will just put a shelter over it.
I will buy some more filler, do the rest of the seams and work around the screws. Then a little bit of sanding and on with the paint. Even if I have to re-do it every other year, it’s all on the same surface, same color. It should be easy to do.
8/12/13
I painted this weekend. Oil base paint is a pain to work with. It is sticky and messy and takes a long time to dry. It is unforgiving too. You can’t just wipe it up. I re-taped the doors to make sure they would come out clean. I was glad I did. It is so much easier doing it that way.
I worried that I had not sanded enough. After putting on the primer you could still see places where the filler showed. I sanded and filled twice. I wondered if I should do it yet again.
Then I realized that I would not be able to make any real improvement. Now, someone else might have, but not me. I had gotten it as good as I could, even though it wasn’t that great. That was a big decision. I had to accept my short comings.
I painted the roof first. The color that matched the top of the car was too dark. I did a couple of strokes and didn’t like it. So I went back and got a lighter color beige. I am so glad I did. It looked a hundred times better.
Always paint the trim first, especially with oil base. It gives you the most room to move around without getting on freshly painted surfaces. I dabbed the brush on the wall first to get the bulk off the brush and then painted the trim. This was good in that I didn’t have any runs in the paint.
I didn’t tape the edges where the two colors meet. I just used a roller. I made sure there was no excess paint on it and went really slow so there would be no splatter. The edges came out really good and it was easy.
I put two coats on. Oil base takes a good 8+ hours to dry. You really need to let it sit overnight before it becomes really dry and hardened. Originally I was going to smooth it out with a brush for that clean look, but I decided to leave the nap. That was a good decision. It hid some of the bad filler work.
I have to say it looks really nice. The semi-gloss looks good and it is solid.
So the only thing I have left are the rails for the hatch. I will put them on tonight when I get home from work. I will measure for the holes and drill them first. I want to make sure I don’t screw them to the hatch before all the holes are drilled to make sure I don’t split one of the rails. If I do, I have to paint a new one, etc.
After that is done, the trailer is done. I can’t believe it. All that work and now it is over. It looks great, much better than I ever thought it would.
- IMG_0343.jpg (130.52 KiB) Viewed 1516 times
