Keep up the great work.
stonykill wrote:looking great. Glad you had a great time. We go away in a week and a 1/2 or so.
stonykill wrote:nice. We put a memory foam topper in our vardo. Very comfortable. We are going the weekend after labor day weekend. The parks tend to be kidless then. We like that
Dirke wrote:Yes, I got the FRP from Lowes. Being that my trailer is ten ft. long I had to use a trim piece to connect the extra two ft. (At the back where the galley is). I would have much preferred to use one 4x10 sheet but the only place I could get those wanted $60 a sheet. I paid $25 and was able to use the leftovers for the front and hatch.
I used a glue that they use for installing tub surrounds but would recommend something else. It seemed to work ok but I had some spots that I had to redo. I know they make a better FRP glue but I don't know the name/brand. My frp is held on mostly by the windows and trim so I am not worried about it falling off. A flush trim router bit does wonders for cutting FRP. I glued the whole 4x8 sheet to the sides and then cut out the corners, door, and windows with the router. Very easy! Just be sure to wear goggles and a respirator!
On a side note, we had our first big storm since I finished the outside. Don't see any leaks!
lilgription wrote:Thanks Dirke. I am contemplating using frp that's why I asked. I will research for some better glue. There are so many mixed reviews out on the Lowes stuff but everyone I see that uses it loves it. The others say it needs to be painted because it has no UV protection. But I read an article where a guy used it for fence panels in between his yard and a school over 10 years ago. No discoloration or chalking yet. His only complaint was having to pop his panels back in a few times because of kids running into it.. lol. I say if it can stand school play ground abuse it will be just fine for use. Thanks again for replying
