bouncing
bouncing
Postby campwithme » Thu Aug 22, 2013 12:05 am
Ok when im going down the road my trailer bounces... need help..
:x
campwithme
Images: 28
Re: bouncing
Postby les45 » Thu Aug 22, 2013 4:35 am
Need more info: what kind of tires? type of trailer? approximate weight of trailer? etc.
les45
Images: 605
Re: bouncing
Postby bobhenry » Thu Aug 22, 2013 5:29 am
Perhaps a better road ? :laughter:
O.K. O.K. I'll get serious...... Tire pressure : can you lower it a bit?
Are you fully loaded as you would be for camping ?
Camping gear can add 150 to 300 pounds !
If this is an old style frame perhaps you are just sprung too heavy.
Re: bouncing
Postby absolutsnwbrdr » Thu Aug 22, 2013 7:10 am
Mine bounces a little too. Havent figured out why yet. :thinking:
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Re: bouncing
Postby campwithme » Sat Aug 24, 2013 6:20 am
ok trailer loaded weights 1000 lbs. I have golf crate tires tried different tire pressures.
campwithme
Images: 28
Re: bouncing
Postby campwithme » Sat Aug 24, 2013 6:22 am
I don't know how to add pics
campwithme
Images: 28
Re: bouncing
Postby Kody » Sat Aug 24, 2013 7:53 am
To paste photos here, go to "Photobucket", register with them, it's free. Choose a name and password for your albums then follow the prompts to upload your photos, Select the photo you want to bring across to the forum. Click on the small box that says "image.....". Copy the image address then go to the "Post a Reply" here and simply paste the address into the box you type into. Do not use any of the formatting from the info bar displayed at the top of this box. Click "Preview" and the photo should instantly appear in the format it will then be seen. It's not hard or complicated to do.
A common cause of bouncing is when the spring leaves have rusted together. If possible, take them off the axle and dismantle them. Run a 4" disk sander on the leaves to remove any rust then lubricate the leaves with grease and reassemble. Lubrication of the spring leaves makes a huge difference to their performance. Some people prefer not to lubricate the leaves as it can lessen the dampening affect due to friction between the leaves but I would lubricate them regardless to make sure they are working. The grease will work its way out eventually regardless.
Kody
Never be afraid to ask questions here, Prov. 11:14
Kody
Images: 22
Re: bouncing
Postby doug hodder » Sat Aug 24, 2013 7:02 pm
Swap out the springs with a pair for a lighter load. Springs are actually pretty inexpensive. With a golf cart type tire, it sounds like you used a pop up trailer axle set up. Pop up's aren't all that light so it was probably sprung heavier than you need. FWIW. Doug
Re: bouncing
Postby Kevin A » Sat Aug 24, 2013 7:55 pm
Is this the frame you used?
Kevin A
The other guy
Images: 289
Re: bouncing
Postby working on it » Sat Aug 24, 2013 9:47 pm
campwithme wrote:ok trailer loaded weights 1000 lbs. I have golf crate tires tried different tire pressures.
I don't know if your tires are like these http://recstuff.com/18.5-8.508-Load-Range-C-Bias-Ply-Trailer-Tire.aspx, but if they are, then you might be overtaxing your tires. At 1000 lbs, you would be 7% over max @ 50psi. Maybe what you're experiencing isn't really bouncing (heavy springs and/or overinflated tires), but the squirming and flex of the tires' sidewalls. Not enough tire for the load. In a similar vein: My accountant father, long gone now, once told me that the shocks were bad or something on his pickup (3/4 ton with 16.5" diameter wheels), so when he dropped by one night, I took a test ride. It sure rode loosely. I asked to drive, and yep, it was squirming even on straight roads. I stopped, got the flashlight and tire pressure gauge, and checked all four tires...10-12psi on all four! (A friend at work had deflated them for him, for driving in snow!) Those tires were intended for 80 psi; I was amazed they hadn't come unseated off the rims. Properly inflated the tires at the first gas station, then the pickup had a firm but really positive feel. It was only two years old, so no problems existed except for gross under-inflation. Maybe not the same situation for you, but the point is that the tires and springs need to be working together and be in the same ballpark as the intended loads carried. My trailer, as usual for me, tests the envelope, but manages to be slightly within its' limits.
173193172890148599
working on it
Images: 457
Re: bouncing
Postby campwithme » Mon Aug 26, 2013 10:10 pm
sorry I didn't use a popup trailer... it was motor cycle trailer... and the only thing I use from it was the axle.
campwithme
Images: 28
Re: bouncing
Postby campwithme » Mon Aug 26, 2013 10:16 pm
gallery/image.php?mode=thumbnail&album_id=2571&image_id=94714 does this help...I think I just need to move the front hanger up and inch...... :oops:
campwithme
Images: 28
Re: bouncing
Postby Kody » Mon Aug 26, 2013 11:47 pm
How many leaves are your springs made with? It's a bit hard to see in the photo. If you have four leaves, try removing one. This will take out the extreme bouncing immediately.
Kody
Kody
Images: 22
Re: bouncing
Postby campwithme » Tue Aug 27, 2013 1:19 am
ok there 1750 lbs. springs and I did remove the bottom spring.... I think there 5 springs
campwithme
Images: 28
Re: bouncing
Postby campwithme » Tue Aug 27, 2013 1:35 am
I hope this pic helps... I think the bracket needs to be moves forward about and 1 in.....gallery/image.php?mode=thumbnail&album_id=2571&image_id=111604
campwithme
Images: 28
