Oldragbaggers wrote:I wouldn't blame the varnish. You shouldn't have a problem over cured epoxy. I am wondering if you used a "blush free" type of epoxy. If you had blush on the surface that wasn't properly cleaned off, perhaps that could be the problem??
Larry C wrote:All epoxies have different cure times. Some are a week or less before applying an approved finish others are a month or more. There has always been controversy in the boat building community regarding which finish is compatible with a given brand of CURED epoxy. with all the recent changes in these coatings formulations to meet environmental requirements, no one really knows if the coating they want to use is truly compatible with the semi-cured epoxy they have used. Only pre-testing will supply this info. Even if it drys and everything seems good, you won't know for sure if it it will hold up over time till you subject it to the environment. It may just fall off, turn cloudy
or hopefully it will be fine
DudKC wrote:Now I have a question...what should the epoxy finish should look like after you sand it down to apply the varnish? The manual I got with the West Systems epoxy just said to sand it to 80 grit. It didn't really say how to do that, so I bought some 80 grit sand paper for my random orbit sander. I started on the roof and it really took off the shine of the epoxy, almost so it looked like bare wood.
I stopped quickly and did some research, on this youtube video (http://youtu.be/rNLQRRDaitE), the guy sanded his with 220, but he did take the shine all the way off.
Just wondering how to move forward here, I do have some 220 sand paper for the sander so that isn't a problem, I'm more wondering about how much I'm supposed to sand it. I have 2 coats of epoxy so it should be thick enough to sand, just how much is the question.
Thanks
Larry C wrote:
Dustin,
If your applying epoxy over wood (no glass) 2 coats is probably not enough to be able to sand smooth without cutting into the wood . Now that you have sanded, I would apply 2 more coats, and try sanding with 120. All shiny spots should turn dull including the small divots, and the orange peel should be all gone. I don't normally sand any finer than 120 grit on epoxy. If you want a truly smooth orange peel free surface, the epoxy coating must be smooth, and dull before applying varnish.
Also, Use the best quality ROS sand paper you can find, and stop frequently while sanding, and scrape the disc with a paint scraper to remove any epoxy that has stuck to the paper.
Larry C
DudKC wrote:Larry C wrote:
Dustin,
Larry C
This is very timely advice, Larry. This morning I sanded with the 220 on the ROS for about 10 minutes before going back to the 80 grit. This took me about 2 hours to get to this point. But I did consider doing more epoxy because I wasn't sure if 2 coats was enough.
1. Do you think you can tell by the picture if I need to do 2 more coats of epoxy? I would say it is smooth and dull for the most part, but there were low spots in the epoxy where it got into the grain and it is still shiny. I only got down to the wood in a couple tiny spots, for the most part what you see is dulled epoxy that could be ready to varnish, but I do want to do it right, so doing 2 more coats of epoxy today isn't the end of the world.
2. Can you explain the orange peel? I didn't really notice anything like that on this epoxy so maybe I missed it?
Thanks!
Prior to the top coat, sand it with a 220. It gives it a tooth to bind the varnish/ paint or clear coat. It also gives it a nice depth to the finish on a clear one.
The real thing here is that too many people try to push it and do things too early, or cut the number of coats on the epoxy. The epoxy is what makes it nice and smooth fills the grain and levels it all...All the top coat does is protect what's under it. There is no quick way to do it...it takes a fair amount of time and patience.
Temperature and humidity and your recipe for epoxy are your keys to making it cure completely. It has to be completely cured prior to the top coat. If it doesn't sand all powdery when you sand and balls up on the sand paper...it ain't ready to be top coated. While I'm not a fan of varnish as it needs attention almost yearly if it sits outdoors, (others may disagree but that's the general feeling with a lot of the wooden boat community) a good "tooth" on the sanding will assist in the finish. Do it in a fine paper, as an 80 grit won't be hidden with the top coat.
DudKC wrote:Referring the the quoted portion of Doug's post, I found that the 80 grit in my ROS was a lot easier to use than 220 on my cured epoxy, but will scuff marks show through the varnish if I only use 80 grit and call it good? I believe Larry said he doesn't use finer than 120 on epoxy, and Doug uses 220 before his top coat. I'm wondering if I should do both 80 then 220, or just scuff it up with the 220, or meet in the middle? hmmm...
Larry C wrote: However, I sometimes do sand finer than 120. As your using Wests epoxy, going through all grits (80,120,180) to 220 may be prudent. Are you sanding between epoxy coats?
BTW/ if your finishing "bright" you should be using Wests 207 hardener as 205/206 will harden with a yellowish tint. 207 is very clear.
Chuckles wrote:Well I got sick of waiting, grabbed a cloth soaked with paint thinner, and started scrubbing. I ended up scrubbing almost 75% of the varnish off... right down to the scuff sanded epoxy. I worry about using paint stripper on the epoxy so I think I'll try more thinner with a scotch-bright pad then give it a few days and sand off the remaining dried varnish.
After a fresh cote of epoxy and lots of dry time I'll start over with the varnish.
