GuitarPhotog wrote:The bigger problem than raising and lowering will be sealing it when it's raised so water doesn't get in while you're towing.
<Chas>
Never really worried about water splashing up while traveling I never even sealed the bottom of my old tear and it was the sides that rotted out on it
CarlLaFong wrote:How far do you want it to drop? I was thinking that it wouldn't be hard to rig up a drop floor that goes all the way to the ground, maybe with four little feet to keep it out of the mud
Don't want it to go to the ground just low enough to give me 6' head height and be able to get it in the garage. But some flip down feet might not be a bad idea to help stable it
KennethW wrote:How about a skirt
I was thinging canvas sided would fold up easy and keep bugs out
On a side note anyone know where you could get the material like what's around the drop floor on this camper I need it for another coveertable top project about 48"x11' https://oldietrailer.shutterfly.com/pictures/100#100aggie79 wrote: You probably ought to check out this thread:
viewtopic.php?f=13&t=33828 . It has a drop floor that raises for travel and lowers at the campground. It is operated by a cable and pulley system.
OK I really like this with canvas sides that could snap or velcro in when down so when I walk (crawl) while it's up I wouldn't have to step over the side. I just need to figure out the plly system from the 3 pictures
Thank you all for some wonderful ideas
