Light weight drawers
Postby Treeview » Sun Aug 25, 2013 12:43 pm
Pretty soon its going to be time to work on cabinets and drawers for the ToyBox. Now I'm gathering info to decide how much I build myself and what's available built.
Here's one set of light weight drawers that I found... :?
http://tinyurl.com/m5glaxu
I have a few of drawers like these already already:
http://www.jeff-z.com/rv/amods/closet-01.jpg
Simple construction like this maybe?
http://4.bp.blogspot.com/-kOpTpZ9Ebh4/UFtc4rPU0WI/AAAAAAAAGKY/L5FNLjuL9r0/s1600/18.jpg
Treeview
Images: 30
Re: Light weight drawers
Postby Mdrinnon » Mon Aug 26, 2013 10:54 am
A combo of ply and plastic storage makes a sturday and decent looking light weight set. When we were keeping snakes and other creepy crawlies we built a rack with plywood, hand made wood J channels, and a set of storage tubs. frame held everything up, ply kept it sturdy and slitherers in place.
I never bothered to take pics of one of mine but this one from google is similar
I had soild plywood between each shelf.
Mdrinnon
Images: 37
Postby Treeview » Mon Aug 26, 2013 10:56 am
That's along the lines of what I'm thinking...without the snakes!
Treeview
Images: 30
Postby Woodbutcher » Mon Aug 26, 2013 7:06 pm
I used these baskets that slide out. Got them at Ikea in the closet department. Ten bucks each.
Woodbutcher
Postby Treeview » Mon Aug 26, 2013 7:43 pm
Baskets are under consideration too. Light and durable. It's a shake of the dice trying to find a plastic unit that is flexible. Too often the plastic is brittle...even at comfy temps, much less when its cold.
Treeview
Images: 30
Postby VijayGupta » Mon Aug 26, 2013 8:25 pm
Another idea using plastic tubs.
VijayGupta
Postby Treeview » Mon Aug 26, 2013 8:29 pm
Tubs and cleats is the simplest setup.
I've been looking on Ikea's website along with some plastic wholesalers. I'd like to find some with a variety of depths but the same length and width. That would make it easy to move them around in the cabinet depending on what I want at the top.
Treeview
Images: 30
Postby Treeview » Tue Aug 27, 2013 11:05 am
I just found this source:
http://www.reallyusefulproducts.co.uk/usa/html/onlineshop/fullrange_rub.php
Lots of heights with the same width and depth to make cabinet construction easier.
Treeview
Images: 30
Postby CMC » Tue Aug 27, 2013 11:47 am
Look at the container store. Might just have what your looking for.
Curtis
Finally the build has started. Oversized Off-road Benroy (Military Themed)
CMC
