Solar Panel Mounts on Thin Roofs
Re: Solar Panel Mounts on Thin Roofs
Postby hankaye » Fri Aug 16, 2013 7:16 pm
Howdy All;
Sorry, When I read it I thought along the lines of 'Spoilers' as something
usually attached to the rear of a car or truck to create a negative air space
and think of a deflector to disrupt the flow so that is goes around or over something.
Semantics, reckon it's all in the usage... :thinking:
hank
hankaye
Postby OverTheTopCargoTrailer » Sat Aug 17, 2013 1:24 pm
p 2-4.JPG (122.05 KiB) Viewed 909 times
I just used a long metal strip with VHB tape & will put screws in to hold panels secure
p 3-2.JPG (111.37 KiB) Viewed 909 times
p 4-1.JPG (129.33 KiB) Viewed 909 times
Click below for larger pictures
Postby wtcreaux » Sun Sep 01, 2013 4:28 pm
I used 2x4 mounts at Home Depot and bent 1 tab 180 degrees to make a "Z".....then screwed into the roof supports.......
105850
then caulk like crazy........seems to work fine.....
wtcreaux
Images: 211
