The Bummer offroad build
Re: The Bummer offroad build
Postby RandyG » Sat Aug 31, 2013 11:00 am
Looking great! Seems like all the major stuff is done.
Randy
RandyG
Images: 115
Postby Silvrzuki77 » Sat Aug 31, 2013 11:56 am
Just alot of expensive stuff left lol.
Silvrzuki77
Postby bpalmer » Mon Sep 02, 2013 9:10 am
looking great plan doing a lot of the same things with mine but I'm just getting started
Bob
bpalmer
Images: 61
Postby Silvrzuki77 » Mon Sep 02, 2013 9:51 am
Let me know if you need any help.
Silvrzuki77
Postby Silvrzuki77 » Mon Sep 02, 2013 9:53 am
Alright todays update! Got a whole 2 hours of combine sleep last night at work lol. Thank god for coffee and beer. Finally got my boat fuel tank vent Im using as a water vent.
Then the big update!!
Got a door installed and the latch catch installed!
Have to order the door trim and seal but have plenty of room for that. Finishing putting the polyurethane on the edges and exposed wood at the moment. Should have the window in tuesday! Then off to the other side.
Silvrzuki77
Postby KCStudly » Mon Sep 02, 2013 10:37 am
Looking great! :thumbsup:
Postby Ron Dickey » Mon Sep 02, 2013 1:17 pm
Silvrzuki77 wrote:First door put together and dry fitted still deciding on which hinges to use.
So I was looking at this for my door and read it is a bear to put in did you have a difficult time or just thinking it out ahead make it work just fine.
Your build looks great and well thought out.
Ron
173882......173887
Ron Dickey
Images: 787
Postby KCStudly » Mon Sep 02, 2013 2:01 pm
Looks like you built the door frame around the latch, rather that trying to fit the latch into pockets in the door frame.
Any concern about the door flexing with the interruption in the frame, or do the skins and inner latch plate add enough stiffness to compensate for the higher stresses at the latch?
I took the other approach, building up the area around the latch with solid blocking, router pockets and hand fitting to accommodate the irregularities.
Your method appears to be easier and lighter.
Postby Silvrzuki77 » Mon Sep 02, 2013 2:28 pm
Yeah i decided to build around the latch. Went realy smooth for the most part had to get a tad longer bolts to hold the inner latch plate on. Soo far with the outer skin 1/2ply and the 1/4" inner ply there is no movement. The handle really keeps everything from moving I think. Time will tell :)
Silvrzuki77
Postby KCStudly » Mon Sep 02, 2013 2:35 pm
Yeah, the screws that came with my latch sets (specified for thicker doors) are too short, too. Where did you get your replacements? Any info on them?
Postby Silvrzuki77 » Mon Sep 02, 2013 2:37 pm
Just ran down to the local ACE hardware and found a longer set. Forgot what pitch it was... Sorry
Silvrzuki77
Postby KCStudly » Mon Sep 02, 2013 2:42 pm
The screws that came with mine are self tapping and the die cast bosses are not threaded. I may have to tap them out and just source screws that are the correct length and head type.
Other option is to contact the supplier and ask for the correct longer screws.
Thanks for the reply.
Postby Silvrzuki77 » Mon Sep 02, 2013 2:48 pm
Oh really? I lucked out then lol
Silvrzuki77
Postby Silvrzuki77 » Mon Sep 02, 2013 6:09 pm
I would without a doubt suggest to anyone buy the premade doors!!!! The amount of time, buying all the trim and the headache i would have been much farther along.
Silvrzuki77
Postby Silvrzuki77 » Tue Sep 03, 2013 7:47 pm
Rocrunr its actually zombies tied to the back of the 2 1/2 ton lol
Well i got my goals acomplished for the day. Installed the driver side window.
Got the passenger side door installed. Big pain in the rear had to router a 1/8th" around the interior door edge by hand. Fits awesome. Started polyurethaning the door.
Tomorrow install passenger window and get the door latch installed.
I need to drive down to the rv place and buy some butyl tape soo i can finish the hatch exterior. Going to order the new leaf springs friday and hopefully a few other things?
Silvrzuki77
Users browsing this forum: Google [Bot] and 0 guests
