Building the "Heart of Gold" - Done 3/9/2014
Re: Building the "Heart of Gold" - started!
Postby drewh1 » Fri Sep 06, 2013 11:06 am
Regan,
You are right, the Ryobi works great for basic stuff. I have used it with a template on the sides and making blocking etc.
i would like to use the router to cut out oval cabinet doors to make the interior storage cabinets (like the Camp-Inn). Oddly, Ryobi does not make and adapter for guide bushings for this router and so I am faced with either changing my plans or buying a new router that accepts guide bushings. Another option is the universal plate and bushings. I may try to adapt a plate to the router. Then I would be very happy with it.
drew.
"If only I knew what I know now when I started . . ."
My Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=56916
drewh1
Images: 7
Postby iregan » Fri Sep 06, 2013 10:51 pm
Hi Drew,
I guess I just don't understand the need for the guide bushings.
I very seldom use mine preferring to use template bits with built in bearing guides.
Cheers
Regan
iregan
Postby KCStudly » Fri Sep 06, 2013 11:04 pm
Guide collars allow you to set the depth of cut to what ever you want, whereas a bearing bit is a fixed length with very little range to make adjustment (especially when using thin ply as template).
Postby drewh1 » Sat Sep 07, 2013 5:21 pm
I think I am going to buy one of these, I can drill it if I have to: http://www.rockler.com/product.cfm?page ... te=ROCKLER
base plated.jpg (18.83 KiB) Viewed 3395 times
and use a whiteside bushing. they come with a centering pin.
drewh1
Images: 7
Postby drewh1 » Sat Sep 07, 2013 5:23 pm
I also laminated the inside panels on my sides. I am all ready to cut out the door holes and then the sides will be ready to mount! I am still able to get things done but am really starting to need the trailer. already about $700 in so no turning back now!
drewh1
Images: 7
Postby iregan » Sun Sep 08, 2013 4:18 am
Lol,
Thanks KC, I understand and use bushings quite often.
I just don't see a need for Drew to have to buy a baseplate and set of bushings for anything we are doing here, and was just pointing that out.
More than one way to skin a cat :)
Regan
iregan
Postby iregan » Sun Sep 08, 2013 4:41 am
Drew,
Be aware that the Rockler base plate has a 1-1/4" hole for bushings, where the bushings for Porter Cable, Dewalt, Hitachi etc use a 1-3/16" bushing.
They even show it with their 1-3/16" bushing kit which is confusing, not sure if they offer both sizes or not.
Most woodworking stores have universal baseplates that you can drill for your router, and harbour freight has a cheap set of bushings that would work fine.
http://www.harborfreight.com/9-piece-ro ... 98361.html
Too bad they don't having baseplates, lol!
Regan
iregan
Postby KCStudly » Sun Sep 08, 2013 9:02 am
I purchased that exact same plate and bushing set from Rockler. They work together correctly and I am happy with them. :thumbsup:
Postby drewh1 » Sun Sep 08, 2013 3:16 pm
I am glad you guys have my back. Thanks!
BTW, here is where I will be next week, although I hope to be underwater most of the time. One of the big reasons I am building my teardrop is so I can go diving/camping.
reefci island.jpg (37.12 KiB) Viewed 3348 times
drewh1
Images: 7
Postby KCStudly » Sun Sep 08, 2013 3:57 pm
You suck!
:lol: :lol: :lol:
Truthfully, I hope you have a very good, and safe time. :thumbsup:
Postby drewh1 » Sun Sep 08, 2013 6:47 pm
yes, totally, but you know I haven't had a f&*g vacation for 4 years! Only problem is I may never come back. If I don't, anyone who is close by can come and claim my plywood!
drewh1
Images: 7
Postby KCStudly » Sun Sep 08, 2013 7:51 pm
4 yrs? I take it back. You deserve a break! Have a good time and take a couple of pics for us to drool over.
Postby iregan » Mon Sep 09, 2013 1:12 am
Wow,,, I'm beyond envious!!!
Have a fantastic time!
Regan
iregan
Postby RandyG » Mon Sep 09, 2013 2:13 am
I also have the Ryobi. I didnt even know what the guide collars were used for, now I feel I chose the short straw. :cry:
Randy
RandyG
Images: 115
Postby drewh1 » Mon Sep 09, 2013 11:27 am
Well, it's fixable! Nothing a little more $ won't take care of :roll:
(I must be gettin old, I love these little emoticons now)
drewh1
Images: 7
