Mary C.
Dale M. wrote:Bottom line basic, if there are flanges on axle stubs, you can probably put brakes on it... Brakes come in 7, 10 and 12 inch for basically small trailers and with weight/brake power matched according to size of brakes (in inches)...
Flange is something like this for example...
IF there is no flanges but if axle stub will accept a drum type hub, you can add flanges (if there is room) ....
Dale
eamarquardt wrote:There's been considerable discussion on the forum about adding flanges to existing axles. No one, to my knowledge, has done it, let alone successfully.
The flanges would have to be positioned pretty accurately if the brakes are to function properly and for you to get a reasonable life span out of the shoes. The factory, I'm sure, has a jig or fixture to hold them in place while welding them in place. You'd have to fabricate something similar to hold them in place and you'd also have to know where to place them. All doable but it would take some thought, planning, and proper execution.
I wouldn't trust your typical welder to do it accurately as I doubt that he/she would have the proper measuring instruments to do a precise job.
Corwin C wrote:eamarquardt wrote:There's been considerable discussion on the forum about adding flanges to existing axles. No one, to my knowledge, has done it, let alone successfully.
I have done it ... however, I was under the watchful eye of a professional welder. It was nearly 20 years ago, and 20-25 thousand miles ago, on a tandem axle car carrier (significant weight.) The brakes still work and I believe still have the original linings and magnets. We used copper shims and the hub/drum/bearing/backing plate to locate the flange then it was a simple matter of tacking to avoid movement from heat distortion and then the final welding. Remove the hub and drum and weld from the inside as well. Any competent welder/machinist worth paying ought to be able to do the job. I do agree that it requires some know how and following solid welding processes and procedures, but it's far from an impossible feat to accomplish. If I needed to, I'm confident that I would be able to do it again.
Now I'm not saying that there aren't situations where it couldn't be done, but it wasn't a hopeless issue to install the flanges.
angib wrote:I don't doubt that fitting a new axle would be both cheaper and easier than adding backplates, but a small devil sitting on my shoulder always asks: "couldn't you just energize the brakes so that they locked the brakes (and hence the backplates) centrally in the drums while you tacked the backplates?"
And setting the bearing grease on fire with the tack weld heat would just be a way of adding some excitement to the day......
Mary C wrote:Ok I spent 2 days looking for an answer and now I need an answer because I have to discuss this with someone making a trailer and I am just not sure. If I want electric brakes, and I for some reason can't find any reference to electric brakes on a torsion axle....sorry I am frustrated...I cant find all the information I need right now I am thinking of getting a torsion axle with brakes for my next build. does that exist? I have not been able to determine if it is possible.
