Rear Ramp/Door Question
Postby foamer01 » Sun Sep 15, 2013 7:42 pm
Any chance you think this might work. Cargo Trailer purchase with rear ramp and have a RV Door installed in it. I really would like a rear entry door instead of side door. However for marketing purposes down the road without a ramp door or barn doors would severely limit the market. I probably way out in left field on the thought process however i like the thought process this forum has. though with a door cut out of the ramp it would make the ramp almost useless, maybe I already answered my question. Thanks
foamer01
Re: Rear Ramp/Door Question
Postby roadinspector » Sun Sep 15, 2013 9:01 pm
foamer1,
It is possible. :thinking: My warped vision is a heavy piece of diamond plate that is reinforced with square tubing that stretches past the limits of the door. It could be where it hinges out of the way or completely removable. It would be about 1 1/2" higher than the rest of the ramp but it is do-able. Just depends on how bad you want it.
I have thought of installing a window in my ramp. I would use the heavy diamond plate to cover it when I needed the ramp. It would not need to be reinforce since the area of the window is smaller. I haven't completely thrown the idea out the window but right now it is more work to modify my ramp for a window than I care to do at this time. (I just don't want it bad enough) :lol:
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby bc toys » Mon Sep 16, 2013 6:05 am
I have 2 ideals to run buy you 1st ideal is to take ramp off and build a new wall with door built in and when you want to sell it down the
road take it out and put ramp door back in. 2nd ideal is build a wall inside just enough so ramp door will close and put door in it
and use ramp door as a porch and they make a tent like thing that will fit on porch/door so you can sit on it out of weather. Well
hope this helped you out.
bc toys
Images: 42
Postby orcadigital » Mon Sep 16, 2013 8:13 am
Building a false wall inside the ramp door is a pretty common way to handle it. Here is a link to a picture (not my trailer or picture, sorry about the orientation)
http://www.rctech.net/forum/attachments ... 10-002.jpg
There are many variations on this, but usually it is building a false wall inside where the rear door closes, and then building in a door (opening, sliding, etc) into it. It is also a way to build in a wall mount air conditioner without cutting into the walls of the trailer. It gets built into the rear false wall next to the door. My friends trailer is that way, but unfortunately no pictures of it.
orcadigital
Postby foamer01 » Mon Sep 16, 2013 2:56 pm
All excellent ideas! Thank you! I wonder why I cannot think of these things on my own. I have another question in regards to the ramp however I will start a new thread. Thanks again for the insight.
Foamer
foamer01
Postby roadinspector » Mon Sep 16, 2013 9:37 pm
foamer01,
Sometimes it takes a different type of twisted mind to come up with off the wall ideas! :FNP Some of them actually work the first time you go for it! :twisted:
Earnest
roadinspector
Images: 127
