The shower
The shower
Postby Shadow Catcher » Tue Sep 17, 2013 5:39 am
Gizmag has pictured a shower which has a couple of nice innovations. It appears to be made of aluminum pressurized by a CO2 bicycle tire infiltrator or pump and using a radiator cap so it can not be over pressurized http://www.gizmag.com/road-shower-car-t ... pictures#7
I would think you could achieve the same results using a length of PVC pipe.
Re: The shower
Postby rowerwet » Tue Sep 17, 2013 6:31 am
http://www.duckworksbbs.com/ProductDeta ... ctCode=RLF
we find this works just fine, nothing to buy, heats up quickly, and plenty of pressure for just a few pumps.
112398
$20 vs. $300
rowerwet
Images: 521
Re: The shower
Postby RandyG » Tue Sep 17, 2013 9:18 am
Here is more info on it, and a video http://www.roadshower.com/
Randy
RandyG
Images: 115
Re: The shower
Postby alex k » Tue Oct 29, 2013 7:04 pm
113968
my home made sink and shower . lawn pressure sprayer with a sink spray handle.
put it in a black plastic bag for solar heat
not to be confused with alexk from california
Green Lantern Corpsman
Coleman Keepers 200A Gang
alex k
Images: 34
Re: The shower
Postby bdosborn » Tue Oct 29, 2013 9:53 pm
Well isn't that a slick idea! I agree, it shouldn't be too hard to replicate in black PVC. It would be great on an off road trailer.
Images: 806
Re: The shower
Postby Shadow Catcher » Wed Oct 30, 2013 6:49 am
OLD post, I bought a Bullfrog shower point from the UK to be used in conjunction with the water heater.
You can see the outlet just above the water heater in the third picture.
Image Image96128
Re: The shower
Postby Ron Dickey » Wed Dec 18, 2013 11:16 pm
bdosborn wrote:Well isn't that a slick idea! I agree, it shouldn't be too hard to replicate in black PVC. It would be great on an off road trailer.
some one was listening to you!
http://www.youtube.com/watch?v=M-J0nOlsG6g
173882......173887
Ron Dickey
Images: 787
Re: The shower
Postby bdosborn » Thu Dec 19, 2013 9:11 pm
Ha. Another slick setup.
Images: 806
The shower, NOT HERE!
Postby noseoil » Sun Aug 03, 2014 8:02 am
This is a great idea, but there's no way I would use it here in Tucson in the summertime. With daytime temps in the 100's many days, that water could be around 140f in the tube. You can't even use water out of the garden house until it runs through to the ground water, 90f is our cold water this time of year, you will be scalded with the water in the hose if it sits in the sun too long. That having been said, it's a nice idea for warming water on the cheap & easy in the right climate. A gravity feed, a hose & sprinkler head and you're in business. Air pressure and you really have an upscale system.
I guess we could use some 6" PVC here in the desert and have plenty of hot water on a trip. That's 1.46 gallons per running foot with a 6" I.D. tube, so a 6' pipe is nearly 9 gallons of hot water.
137905
noseoil
Images: 670
