Bruce, thanks again for your information. SC thanks for yours about camping in less than full sun too. I'll mess around with PV Watts some more. Santa Maria is 30 miles south and is similar for climate calculations. It would not represent the solar radiation available where I may travel which could be greater, or less.
If a chest style (top opening) fridge/freezer like Bruce's Waeco 40, or a similar sized Truck Fridge TF41, or ARB 37,
uses on average 12 amp hours daily that is much lower than 20 AH or so daily I estimated one would use. Very, very good if usually true to life.
I am considering using a computer fan to draw (cooler) fresh air into the cabin from under the floor. It would be on a switch, and maybe a thermostat too. That could reduce power used by a Fantastic Fan. The Fantastic Fan, a 5000rbt, I will use has a thermostat to turn it on or off as needed. So it (FF) will only use power intermittently. (I like the lower power used by a 14 speed 6600r/417
http://www.fantasticvent.com/products/products.html or
http://www.rvvent.com/6600r.htm but they are too costly for me to justify)
All cabin interior, galley and porch lights will be LED so they should not use much power per day.
I do not plan to install or use an inverter which hogs power. Nor an air conditioner, heater, TV, any electrical cooking, warming, or coffee brewing devices, water heater or water pump.
A fridge/freezer is the one "luxury" big user of power.
I may use 12 volt bed warmer pads if I winter camp. I don't contemplate any other high power usages.
All this is to say it seems that a 12 volt 125 watt solar collector, with a 100 amp or so deep cycle battery for power storage, a PD 4045 for AC/DC power and battery charging when hookups are available, and charging from the tow vehicles alternator when traveling may be adequate, or more than adequate for my teardrop. I estimated using between 20 and 30 amp hours daily. Most of it used by a fridge/freezer.
The choice of whether to use a pwm or a mttp (my preference) controller may not be one of absolute necessity but one of wanting to utilize an extra edge that takes
no extra ongoing effort to harvest the maximum amount of power possible each day...treating myself to a nicer luxury, maybe a little bit of glamping.
Portable solar collectors could be an option if the roof top solar panel is sometimes, or often,
inadequate to keep the battery higher than 50% discharged (SOC?) after about 3-4 days of camping. I would most likely get on the road again after that time and charge from towing, or may have access to AC power to recharge the battery.
If I can boondock off grid for a week or so beginning with a full battery and collecting the weeks solar harvest, so as to not run the battery down any lower than 50% that would be golden. Even more golden would be to keep the battery fully charged from solar power while boondocking.
Getting a bit goofy, I don't plan to use an electric blender to make pitchers of icy margaritas (though that could be mighty nice) or to make big bags of pop corn in a microwave nor to watch TV or play loud music while camping in a teardrop. Will not air condition a side tent either.
Sorry for my long windedness
