KCStudly wrote:Well Gus, technically we are both wrong.
The formula for a rectangular shape rib is: Moment = (width x height^3 (cubed)) / 12
So the answer is, "it depends". I may have exaggerated, but it is more than double.
Larry C wrote:eamarquardt wrote:
Actually, I think laminating the rib was easier than cutting a bunch of pieces out of plywood and gluing them all together. In addition, the only wasted material was that which was lost from the saw kerfs. Minimal. Also I really like the side view of all the laminations.
Just my two cents.
Cheers,
Gus
Gus,
Your plywood lamination's look great. Did you run them through a thickness planer or were you able to keep everything level during glue-up? I had to run mine through my planer. I agree this method is MUCH easier, and cost effective over cutting from plywood. I will be using it for my hatch as I did for my perimeter profile.
KCStudly wrote:I was able to run my galley wall edge lamination thru the planer; just had to walk them thru the curve as it fed. I was not even close to that tolerance with variations between slats.
I hadn't planned on this inaccuracy, so I had to scab a layer of 5 mm ply back on the sides of the parts to make up for it, but since they ended up buried under other construction it was not an aesthetic issue for me. Knowing what I know now, I would have made my slats wider and planned on planing to the final thickness.
Be aware that, just because they come out of the mold without spring back, does not mean that they are stable. The plywood slat version will probably do better, but the fir I used opened up nearly 3/4 inch with a change in season (made in spring, installed in summer). I would recommend sealing and or installing as soon as possible.
Gage wrote:The two teardrops that I have built I skined them with 1/8" birch and have had no problems. I wonder why being how every one else either uses two sheets of 1/8" or one sheet of 1/4".My teardrop is 11 years old and has been in all kinds of weather and no major problems.
eamarquardt wrote:I cut some 1/8 BB ply into strips and laminated a test rib.
I preformed the pieces into a tight circle to reduce springback when I glued them up. I clamped them to short pieces of angle iron screwed to plywood as a form. Preforming them was unnecessary. When I did the actual gluing up of the rib I used c-clamps as they worked better than the spring clamps.
Here is a picture of the finished laminate.
Here is a picture of the finished rib. There was no springback when I removed it from my jig and it is exceptionally stiff. The advantage of this technique is that a lot of the grain is parallel the entire length of the rib which makes it far stiffer than a rib cut out of plywood.
Just my two cents.
Cheers,
Gus
raven1 wrote:Can you tell me what the 1/8 x 9/16 edge seal that Len used is called where it can be found?
