Man-O-War Spar Varnish over Raka Epoxy
Postby kookenotes » Sat Sep 21, 2013 11:03 am
What is the recommended cure time on Raka Epoxy (no cloth) before applying the spar varnish over it? I'm putting on a last coat of epoxy on some trim parts and want to get the spar varnish on as quickly as possible. What have you experienced? I can't find any posts where it has been addressed. Thanks for the help. Bill
kookenotes
Images: 71
Postby nevadatear » Sat Sep 21, 2013 3:58 pm
There actually was a recent post where that topic was incorporated in a post about length of dry time. I used Raka and man o war, but due to how we built, it was several months before i varnished. You want to make sure the epoxy has off gased. Contact Raka.
nevadatear
Images: 171
Re: Man-O-War Spar Varnish over Raka Epoxy
Postby Larry C » Sat Sep 21, 2013 4:17 pm
kookenotes wrote:What is the recommended cure time on Raka Epoxy (no cloth) before applying the spar varnish over it? I'm putting on a last coat of epoxy on some trim parts and want to get the spar varnish on as quickly as possible. What have you experienced? I can't find any posts where it has been addressed. Thanks for the help. Bill
The longer you can wait the better. I have used Raka for years, and I always wait at least a month before applying Pettit Flagship varnish. IMO/ there are only a handful of Spar Varnishes that truly offer UV protection. I suggest you research the subject before committing to applying any finish. Also, you should do a test spot to make sure your chosen coating is compatible with the CURED epoxy.
:beer:
"If its worth doing it's worth doing Light"
http://www.tnttt.com/viewtopic.php?f=50&t=35852
Larry C
Images: 78
Postby fire on water » Sat Sep 21, 2013 4:39 pm
Raka epoxy also has a epoxy with uv inhibitors in it and it does not blush as some do.
fire on water
Postby kookenotes » Wed Sep 25, 2013 9:35 am
Thanks for the responses and the advice. I have used this combination in the past with excellent results but always had an extended waiting period between the two. I was trying to rush through a small part of the project last weekend when RAKA was closed. As you all suggested, I waited and talked with them on Monday. They suggest 7 days minimum cure time and longer is better although not necessary. I've got too much time and sweat in this project to rush through the end. I am just getting very close an getting impatient. I'm like the cartoon of the two vultures with the caption 'Patience my @$$, I'm going to kill something' :lol: As usual, the guidance from this group is always timely and valuable. Again, thanks to all of you. Bill
kookenotes
Images: 71
Postby _Ryan_ » Wed Sep 25, 2013 10:26 am
I used West epoxy with the 207 hardener (non blushing clear) and I only waited 24 hours before sanding and applying my first coat of Flagship 2015 spar varnish. Three months later and not one problem to speak of. :D
_Ryan_
Images: 356
