Flexiride axle
Flexiride axle
Postby Kim Armstrong » Thu Sep 19, 2013 10:06 pm
Can someone tell me what size pilot hole is needed in a wheel for a 2000lb. axle? Southwest wheel said 3.19 inches but he didn't sound for certain. Sounds kinda big and where do you get plain steel wheels with a hole that big. All the wheels I've seen are 2.750. The wheels I got have a 2.750 hole. 14" wheels. Thanks.
Kim Armstrong
Re: Flexiride axle
Postby angib » Fri Sep 20, 2013 5:09 pm
Going by the highly unscientific means of scaling off a drawing, I get a hub diameter of about 2.5 inches or maybe 2.6, but some way short of 3.19.
Seems worth asking UCF on Monday.
angib
5000 Club
5000 Club
Images: 231
Re: Flexiride axle
Postby Kim Armstrong » Fri Sep 20, 2013 6:31 pm
Thanks Angib
Kim Armstrong
Re: Flexiride axle
Postby bdosborn » Fri Sep 20, 2013 7:42 pm
Trailer wheels are different from auto wheels. The trailer hub is generally larger as the wheels are lug centered instead of hub centered like on cars. Flexiride uses Dexter hubs, here's some info on the hub:
Hub Info
Also, trailer wheels have zero offset, auto wheels typically don't.
P.S. Check out the trailer wheels, the 13-14" all have 3-1/8" holes...
Trailer wheels
Images: 806
Re: Flexiride axle
Postby Kim Armstrong » Fri Sep 20, 2013 9:17 pm
Thanks bdosborn, Most of the wheels I've seen on Etrailer and on S.W. Wheel sight have been 2.750. Really want to use a flexiride axle. Will look at the info you gave. Thanks again.
Kim Armstrong
Re: Flexiride axle
Postby Esteban » Sat Sep 21, 2013 5:38 pm
Kim Armstrong wrote:Can someone tell me what size pilot hole is needed in a wheel for a 2000lb. axle? Southwest wheel said 3.19 inches but he didn't sound for certain. Sounds kinda big and where do you get plain steel wheels with a hole that big. All the wheels I've seen are 2.750. The wheels I got have a 2.750 hole. 14" wheels. Thanks.
Kim Armstrong wrote:Thanks bdosborn, Most of the wheels I've seen on Etrailer and on S.W. Wheel sight have been 2.750. Really want to use a flexiride axle. Will look at the info you gave. Thanks again.
Kim, There are several more places to look for wheels you may like.
Wheels and Tires lists many suppliers.
Shaddow wheels often have center bore sizes of 3.19" or 3.30". Click on their Get More Details button for any wheel to see.
Shaddow 14" white steel spoke wheel with 3.3" center bore
Recstuff wheels specifications show center sizes too. A random one was 3.19".
Recstuff 14" white steel wheels with 3.3" center bores
etrailer 14" white steel wheel with a 3.19" pilot diameter several others are the same
Rim dimensions: 14" diameter x 5-1/2" wide
Bolt pattern: 5 on 4-1/2"
Wheel bolt size: 1/2"-20
Pilot diameter: 3.19"
Capacity: 1,870 lbs at 50 psi
Steve - SLO, CA
Esteban
Images: 15
Re: Flexiride axle
Postby Kim Armstrong » Sun Sep 22, 2013 5:32 am
Thanks everyone for all the info. I guess I may have to change stye of wheel. I was wanting just a plain steel wheel non spoke like a dexstar wheel. Will let you know the outcome.
Kim Armstrong
Re: Flexiride axle
Postby Esteban » Sun Sep 22, 2013 10:29 am
Kim Armstrong wrote:Thanks everyone for all the info. I guess I may have to change stye of wheel. I was wanting just a plain steel wheel non spoke like a dexstar wheel. Will let you know the outcome.
Maybe one of these:
14 x 6 Solid Steel Trailer Wheel 5x4.5 White Painted
14 x 6 White Painted Steel Modular Trailer Wheel 5 on 4.50 Bolt Pattern
Dexstar Steel Mini Mod Trailer Wheel - 14" x 6" Rim - 5 on 4-1/2 - White Powder Coat
http://recstuff.com/14X6-5-4.5-White-Mod-Trailer-Wheel.aspx
Americana Tire
Google images Dextar Wheels
Steve - SLO, CA
Esteban
Images: 15
Re: Flexiride axle
Postby doug hodder » Sun Sep 22, 2013 6:32 pm
I've used old Mopar wheels with no problem on the Flexiride with a 5 on 4.5" hub. You can get them up at a pick and pull or junkyard pretty inexpensively beats the price of a new wheel and you're probably going to want to paint or powdercoat them anyway. Doug
Re: Flexiride axle
Postby Kim Armstrong » Sun Sep 22, 2013 7:48 pm
Thanks Doug. So the center bore is large enough on a stock rim to fit on the axle?
Kim Armstrong
Re: Flexiride axle
Postby aggie79 » Sun Sep 22, 2013 8:55 pm
Don't know if it helps bit I've got steel car wheels on my dexter axle. I was more worried about being able to fit the moon hubcaps than the wheel fitting over the hub.
Re: Flexiride axle
Postby Kim Armstrong » Mon Sep 23, 2013 4:55 am
Aggie, Who did you get your wheels from? Those are what I'm looking for. Thanks
Kim Armstrong
Re: Flexiride axle
Postby alaska teardrop » Mon Sep 23, 2013 7:53 am
    Kim,
    Vintage Trailer Supply sells steel wheels & moon caps made for trailers. Note that the wheels have a 1/2" inset (positive 1/2" offset) & 2.62" center hole that fits Dexter hubs.
    Hub Info
    Fred
alaska teardrop
Re: Flexiride axle
Postby Kim Armstrong » Mon Sep 23, 2013 8:53 pm
Thanks everyone. Called UCF today and they said the hub was 2 1/2".
Kim Armstrong
