lrrowe wrote:Option 3 it is.
orcadigital wrote:lrrowe wrote:Option 3 it is.
I want to wire in the panel with the DC switches, but I need to cut the 1/4 ply that it mounts into, which I can't do until I get the 4x8 sheet up on the right wall and cut down the remainder for the rest to see what I have left. I can't do that till I get the insulation in, which I cannot do till I rework the mounting for the side door bar/latch, which I cannot do till I put in the door lock/handle...etc etc. It's amazing sometimes how the one little thing I am motivated to do, involves a dozen hours of big things before I can start it.
nitro_mt_racer wrote:Are you thinking standing or sitting height workbenches? Are you also planning to make them removable like mine or fixed?
orcadigital wrote:First, thank you for all of the kind replies. It is due to this forum that I have gotten as far along as I have, and all of the great people who pioneered this process before me.nitro_mt_racer wrote:Are you thinking standing or sitting height workbenches? Are you also planning to make them removable like mine or fixed?
Sitting height, so somewhere in the 31"-32" counter height range. While standing/stool height will work, the trailer feels a lot smaller with taller counters. I have a stainless garage workshop height table I have used, as well as the lower folding tables, and I prefer the lower. Also more chair options (and comfortable chair options) with the lower height. I built the front counter at the same height as well. The lower 2 door cabinet is an upper kitchen cabinet and 30" tall. With a 1x2 spacer on the bottom (so the doors open smoothly) and a 5/8" thick counter, that puts me right in the ballpark. It also gives me the additional few inches above the counters for shelves, etc.
I will be making them removable, but still back and forth on exactly how. My first and still current thought is to use e-track at counter height and floor height, and using the end anchors they have, built out a 2x4 frame horizontal from the wall at counter height, then angled back legs to the track at the floor. This would cause less interference with the legs if they came straight down, and hopefully would not compromise too much in strength. I could also fully suspend the rear counter with 2x4's left to right across the back of the trailer for those times I need to pit a 3rd person. The other options are just the counter height etrack and legs straight down in the front, or fully freestanding like you did. I am trying to balance cost, sturdiness, usability, and the ability to move/remove the counters by myself.
I also need to make sure to keep clear of the converter box in the front (did not think about the counter support/leg when I was determining where to put the converter).
I still need to make a boxed in tower for the left rear corner of the trailer that is removable, but attaches to the wall and can hold the AC unit.
