7x14 H&H Cargo trailer Toy Hauler conversion
Re: 7x14 H&H Cargo trailer Toy Hauler conversion
Postby bc toys » Thu Sep 05, 2013 9:11 am
you are doing some great work thats how I am planing on to my cabinets up front was thinking a bout a galley but I do all my cooking out on tables anyway so why would I put out all the $$ for a galley in back. Thanks for all the great pics. Like your windows
bc toys
Images: 42
Postby OverTheTopCargoTrailer » Thu Sep 05, 2013 11:02 am
Say I was just wondering, how do you you guys attach your cabinets ?
nobody ever shows any details ?
Postby lrrowe » Thu Sep 05, 2013 12:44 pm
While I have not done it yet, I was thinking of adding some 3/4 board where the insulation should go to act as a secure point to screw in to. That is 3/4 and I hope to add another 3/4 in over that of foam sheet. I have done this in home construction before and it saves the need to find the "stud".
Bob
Bob
lrrowe
Images: 439
Postby cornfused » Thu Sep 05, 2013 12:49 pm
The center cabinet in my setup us secured with a 2x2 angle Iron with holes drilled in it on both sides screwed into the floor. I built my own bases for the two cabinets on the ends out of 2x4's that are also screwed to the floor. The sides of the cabinets are also screwed into the walls of the trailer. The outer cabinet by the fridge is also screwed into the front of the "V" to a 2x4 I ripped a 30 degree angle on so I could screw to the side of the cabinet and angled part of the "V." If you look close at the cabinet pictures you can see the angle iron and angled 2x4 in a couple of the pictures.
cornfused
Postby cornfused » Fri Sep 06, 2013 8:21 am
I got the rear stabilizer jacks welded on last night. Also, just as a warning to any one else, the factory undercoating that H&H trailer sprays under their trailers is extremely flammable... so be care full if you have to weld anything to the frame.
UP
Down
cornfused
Postby OverTheTopCargoTrailer » Fri Sep 06, 2013 8:46 am
Well that makes me feel better that I'm not the only nut case
That uses hurricane straps to secure his cabinets to the floor and walls
I even screwed the cabinets to each other
I have a feeling we are going overboard a little :thinking:
The jacks look good, however mine scraped on the driveway ramp so OTTCT 2.0 has none
At this point.
Postby orcadigital » Fri Sep 06, 2013 1:56 pm
OverTheTopCargoTrailer wrote:Say I was just wondering, how do you you guys attach your cabinets ?
Not that I know what I am doing compared to many experts here... My cabinets are all upper kitchen cabinets from Ikea. They are made to mount on a hanging rail that ties through the back into the sides of each cabinet. I ran the rail for the upper cabinets and am hanging from that, with a 2x4 "ledge" that they sit on. I will also add in an L bracket on the bottom to keep it secure from twisting on bumpy roads.
The lower is attached with the same rail behind it, and then some longer pan head screws through the base into the 1x2's that lift the cabinet off the trailer floor (and allow the full height/width doors to open without scrubbing).
I was limited to upper cabinets due to depth (trailer is only 15" between the side door and the front of the trailer) while a standard base cabinet is 24" deep. Also, due to my shorter trailer height of 5'5", and that the work benches will be nearer to a standard desk height of 31", the upper cabinets also fit the bill at 30" tall instead of the standard 36" tall that base cabinets are. Unfortunately on my base cabinet, this meant nothing with drawers (which I would have preferred). The plus side is Ikea cabinets are fairly sturdy, inexpensive, and look nice. Most of all, they are better then anything I could craft myself.
orcadigital
Postby cornfused » Mon Sep 09, 2013 8:49 am
Well, after looking at the quote I got to have a pro put in the counter top ($250ish), and seeing that I could get an 8' long chunk of counter top for $49 from a big box store. I decided to try and tackle this myself. I first took some measurements then cut out a patten from plywood to double check the fit. I made a couple modifications and then transferred the plywood pattern to the counter top. I cut out the straight lines with a circular saw from the back side and did the radius' with a jig saw. I was surprised at how easy the laminate cut and it left a nice smooth edge also. I also got my 3ft LED light strips mounted above the counters this weekend as well. It was nice working in the air conditioned trailer also since it was a hot and humid weekend.
"V" fitup
Added some weight to help set the construction adhesive and keep the counter top flat against the cabinets.
cornfused
Postby orcadigital » Mon Sep 09, 2013 5:03 pm
Looks great!
Did you use any screws to mount the counter or is it just adhesive? I have two cabinet doors that I am looking at making into a counter, but not sure that the adhesive will be enough long term.
Thanks!
orcadigital
Postby roadinspector » Mon Sep 09, 2013 8:20 pm
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby cornfused » Tue Sep 10, 2013 8:15 am
orcadigital wrote:Looks great!
Thanks!
I did put a few screws in also, but not as many as I would have liked. It is a good idea even in houses to put down some kind of contact adhesive because when you have a row of cabinets screwed together the top will never be completely flat, so the adhesive helps to fill in the gaps to make it a lot more solid.
cornfused
Postby cornfused » Wed Sep 18, 2013 8:22 am
Well, I finally spent the night in the trailer last weekend on an air-mattress. I've used it a couple times already, but this was the first time I was far enough away I needed to stay in it. Went pretty well, seems like it might be nice to have a little more cabinet storage, and I need to figure out a way to keep the fridge from sliding out from under the acounter. Also, before I left I got my powered roof vent installed and most of my aluminum trim on the inside to hide the panel seams.
cornfused
Postby hankaye » Wed Sep 18, 2013 10:07 am
cornfused, Howdy;
You could use a small/short 'L' bracket screwed into the deck ... ?
hank
hankaye
Postby cornfused » Wed Sep 25, 2013 11:28 am
I think I will screw a leftover piece of the aluminum trim I have to the floor to secure the fridge, looks like it will be just about the right size too.
Now, to get peoples minds working. I need a winch mount in the trailer. Either something easily removable, or mounted out of the way. My ideas right now are to make a mount that will double as a shelf above the counter bolted to the V in the front of the trailer (the V front is beefy, 1x1's every foot) or cut a hole in the floor, and install and vertical "reciever hitch" bolted to the frame cross members so I could easily remove the winch when not needed and put a plastic plug over the hole.
Right now I am using the e-track as an anchor point and 2 2x4s across the trailer. It works, but it's a pain to stepover and remove.
cornfused
Postby hankaye » Wed Sep 25, 2013 8:36 pm
cornfused, Howdy;
Something like this ...?
http://www.amazon.com/WARN-885000-Corde ... able_Winch
hank
hankaye
