nrody wrote:I used a strip of used fire hose, split it lengthwise and used aluminum flat stock 1" wide x width of trailer along with butal tape (putty tape) and self taping screws to affix it. You may be able to get a length of hose from a local fire station that has some damaged hose around.
the hunter wrote:so i was out work on my trailer and it was raining had the gally door open and noticed it was leaking at the hurracane hinge. from the hatch side when the hatch is open, its seam that the water fills the hinge then leaks in ...
the hunter wrote:thanks for all your input , who is this grant guy and how do i contact him..
