Prototear wrote:Aha! I found your build journal viewtopic.php?t=57433 and see what you are doing and why you'd want to keep it simple. I think your idea of a couple wooden rails epoxied on would work so long as there is enough structure underneath it so it doesn't flex too much and weaken over time. I can't tell how thick your roof material is, but if it is thin you could put the wooden rails above your internal cross members. Another approach might be to use black pipe (essentially similar to Yakima cross bars with no coating) since they are pretty stiff with a couple elbows, flanges and short standoffs for each one if you can find a cheap source (buying these new can add up).
Consider that I am building my first teardrop so I can't speak from experience on how these would hold up over time on a bumpy road, only judgement from the pictures in your build journal.
Juneaudave wrote:I screwed my homemade rack right into the roof and sealed it with a gasket and 3M 5200. No leaks in 5 years.
