Need to add side door on 5x8
Postby dpjeansonne » Fri Sep 27, 2013 12:55 pm
I want to convert my Haulmark 5x8. The first thing I think need is to add a side door. My question is buy or make one.
Where (what suppliers) can I find a reasonably priced door? What is the dimensions required?
Is it reasonable to make one myself or the savings are minimal?
Any input is appreciated.
dpjeansonne
Images: 20
Re: Need to add side door on 5x8
Postby OverTheTopCargoTrailer » Fri Sep 27, 2013 1:10 pm
Earnest where are you ? this question is for you I'm sure
Postby jimbo5971 » Fri Sep 27, 2013 6:40 pm
I can say from experience that adding a side door can be a ton of work. I built mine from scratch.
110107 110106 110105 110104
jimbo5971
Images: 60
Postby dpjeansonne » Fri Sep 27, 2013 7:16 pm
Jimbo
Yours came out great.
Did you have some plans to go by? Where did you buy the parts?
dpjeansonne
Images: 20
Postby jimbo5971 » Fri Sep 27, 2013 9:15 pm
Thanks for the compliment, it was a long time in the making. It originally started out as the same design as my rear barn doors. After that became a fabulous disaster (story for another day) I spent a lot of time looking at trailers to help come up with my design. It is really a quite simple design. Most of the supplies you can find at any big box hardware store (Lowes, Menards, Home Depot). Made of aluminum, plywood, FRP Panel, and the original skin cut out from the new opening. For the hardware, I have a local trailer shop that had everything in stock for decent pricing.
jimbo5971
Images: 60
Postby roadinspector » Fri Sep 27, 2013 10:58 pm
dpjeansonne wrote:Jimbo
I agree! :applause: I can tell that was a lot work to do. I don't think I could beat that design. Looks very sturdy and would be easy to insulate and a sheet of plywood to cover it on the inside. Better made than most CT doors that I have seen.
The main benefit of an RV door is you would just have to build the interior frame and cut your hole. They also generally come with a screen door. They are not cheap. Here is a link that sells about whatever size you would want.
https://www.randgsupply.com/Warehouse/Doors/rv/squarecornerrvdoors.htm
I would suspect that Jimbo probably has less than 1/2 the cost in his than these sell for. Both have their benefits but the $> generally rules which way I go.
Good luck with your build!
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby OverTheTopCargoTrailer » Fri Sep 27, 2013 11:18 pm
That's a min $500 door, even I'm getting cold feet :cry:
Postby bc toys » Sat Sep 28, 2013 8:26 am
I built my side door in my 1st 5x8 and would recommend buying a RV door from a scrap trailer and getting frame and door cutting it to fit your needs but if you want to build one you sure can do it.
bc toys
Images: 42
Postby MtnDon » Sat Sep 28, 2013 10:05 am
If anyone wants to try their hand at building a door with screen door like a genuine RV door set, the hinges are available at http://store.lci1.com/rv--cargo-entry-d ... s-c46.aspx scroll down to bottom and also on top of page 2
MtnDon
Images: 24
Postby kyfly » Sat Sep 28, 2013 11:01 am
I recall seeing on another forum someone installed tear drop doors on their cargo trailer. This may be a cheaper, easier option if you can live with the smaller size.
kyfly
Postby dpjeansonne » Mon Sep 30, 2013 7:35 pm
kyfly wrote:I recall seeing on another forum someone installed tear drop doors on their cargo trailer. This may be a cheaper, easier option if you can live with the smaller size.
I am trying to make as large a door as can fit in the space. I think the tear drop doors are smaller than I would like.
dpjeansonne
Images: 20
Postby Wild Bill » Tue Oct 01, 2013 8:36 pm
Not sure where you are located, but you should be able to find a surplus RV Door with a screen complete for less than $100 bucks. Cheaper than the hinge and materials that you will have to purchase and a window if you want one as well. Again all depends on where you are located. In Indiana, Michigan The capitol of trailer builders they are many. Good luck with what ever you decide to do. Bill
Beavers are Naughty!
Wild Bill
Images: 63
Postby dpjeansonne » Mon Oct 07, 2013 10:58 pm
Thanks for all the input. As of now I am looking at the cost of buying a larger trailer.
dpjeansonne
Images: 20
Postby Prem » Mon Oct 07, 2013 11:37 pm
Optimal. :thumbsup:
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby Shadow Catcher » Tue Oct 08, 2013 4:22 am
Our tear has doors made by Challenger door who make them for all sorts of trailers. An Amish Mennonite symbiosis company with good quality work.
