hikediveexploregirl wrote:WorkingOnIt,
When you get a chance can you post some pics from further back so we have an idea of your whole setup? Is this a galley setup in the back where the door/ramp is?
Thanks for your input. I look forward to hearing about how it works!!!
I haven't used it in the wild, but set it up and ran it a coupla days before the DinoValley trip on 9/27/13. No pictures yet taken of it working, though here's a picture of it alone in the galley/storage area:
- generator
- face-on%20view%20of%20rear.jpg (5.33 KiB) Viewed 2479 times
It slides straight out about a foot, then rotates counter-clockwise so the exhaust faces the curbside (and exhausts 6" beyond the sidewall). A tubular steel brace fits under the slide out, and supports the weight while running/vibrating. The three drawer slides have the combined weight rating of 105lbs (the genny and swivel base weigh about 65lbs), and if the genny is only pulled out 8", the brace is not needed. I ran it for an hour in my garage, and the brace remained rock-solid throughout (the genny is rubber-mounted on the wooden slide-swivel bases, to minimize hard vibrations). I will try to get some pictures of the set-up in action, this weekend. The swivel feature was necessitated by the 22" space I put it in; if I had the typical teardrop rear slope, there would have been enough room to just slide it in and out.
