Generator door upgrade...
Re: Generator door upgrade...
Postby hikediveexploregirl » Thu Oct 03, 2013 9:09 pm
That is awesome! I look forward to hearing how the weekend goes!! Nice job!
- HikeDiveExploreGirl
"Anything worth doing is worth doing well"
"If it were easy then everyone would do it."
hikediveexploregirl
Postby working on it » Sat Oct 05, 2013 4:45 pm
hikediveexploregirl wrote:That is awesome! I look forward to hearing how the weekend goes!! Nice job!
I went camping last weekend, not this one. Never needed the generator; so here are pictures I took today, to show what I meant in my previous post (full descriptions are under photos in my gallery):
  • 113093 pulled out, turned, mounted on brace, pushed forward to locating stop pin
  • 113094 better view of brace & pin
  • 113095 shows air gap for exhaust
  • 113096 rubber vibration isolators
173193172890148599
working on it
Images: 457
Postby bdosborn » Sat Oct 05, 2013 6:14 pm
I put a Yamaha 1000 in the tongue box. I added doors for air to go in and out of. I added a tray above the generator for storage and a light so I can start it at night.
If you've ever wondered if putting the generator in a box makes it quieter, well you be the judge. Here's my very unscientific test:
Images: 806
Postby bdosborn » Sat Oct 05, 2013 6:54 pm
P.S. I got the idea from Dan Hazzard:
I'd get a Champion Inverter generator if I was doing it all over:
Champion Generator
Images: 806
Postby eamarquardt » Sat Oct 05, 2013 7:31 pm
bdosborn wrote:I put a Yamaha 1000 in the tongue box. I added doors for air to go in and out of. I added a tray above the generator for storage and a light so I can start it at night. If you've ever wondered if putting the generator in a box makes it quieter, well you be the judge. Here's my very unscientific test:.................
In or out of the box the sound is, IMHO, annoying. I was once anchored in a cove at Santa Cruz Island and was running my SCUBA compressor. There were CHEERS and CLAPPING when I was done and shut it down! I too was cheering and clapping.
I'm sure you use the generator only as a last resort.
Cheers,
Gus
eamarquardt
Images: 150
Postby Shadow Catcher » Sat Oct 05, 2013 10:02 pm
I have a jumper cable and 150A powerpole connectors so I can hook the TV battery/alternator to charge the tear battery, haven't had to use it the solar panel works well. Car on idle uses .34 gallons per hour and much quieter than the generator.
