dpjeansonne wrote:Does a factory side door come with RV type latches or do have to add/modify one to get that feature instead of the cam lock design?
Dirtclod wrote:Hankeye,
I had seen that before on a trailer but the way that the handle is bent it wont lay flat if opened 180 degrees so it wouldnt work in a standard latch. I thought about drilling a hole in the handle and locking it around the bar but I havent found a lock that has a radius big enough to do this.
dpjeansonne .. sorry about the thread hijack but something to think about if leaving the cam lock on but definitley get a RV latch installed from the factory if you can. I heard they were not that easy to install on your own so I didnt want to tackle it and had my trailer built with it.
