OverTheTopCargoTrailer wrote:I started around june this year, on OTTCT Version 2.0 but I skip around a lot with different parts....
but this should help you get started - just start here and go till todays date.
http://overthetopcargotrailer.blogspot.com/2013_06_01_archive.html
Jerry
hikediveexploregirl wrote:OverTheTopCargoTrailer wrote:I started around june this year, on OTTCT Version 2.0 but I skip around a lot with different parts....
Okay, so I got it. You have exterior metal, then plywood, then 3" insulation (1.5*2), then 3/8 plywood, and then paneling.
Let me know what the electrical and insulation issue was. Thanks!!
Jerry
So, you had them build it (custom) with plywood exterior between wood studs and alumimum skin. Then you added 1.5" Dow Blue Board. Then you added interior plywood, correct? You put R19 in ceiling and 2.5" foam on floor. My internet super sucks and it takes me FOREVER to ho through your blog.
Didn't you say something about one of the insulations being bad for wired? Which one was it?
