Build thread: One-man Sleeper
Postby eggsalad » Tue Oct 08, 2013 10:51 pm
Well, that's the name. It sleeps one, with not much room for anything else. It's also shaped a bit like a coffin. I haven't used my carpentry skills for a long time, so it is what it is.
Here's the starting point. A PWC trailer from CraigsList for $160:
Stripped off the boards, extraneous hardware, and decals, then primed:
Bottom side got cleaned and primed as well:
eggsalad
Re: Build thread: The Coffin
Postby eggsalad » Tue Oct 08, 2013 10:53 pm
These lynch pin thingies had to go:
Whacked off with a cutoff wheel, and primed the bulkhead:
eggsalad
Postby eggsalad » Tue Oct 08, 2013 11:00 pm
Couple of sticks of 2x4, ripped down to 3", make up for the dropped crossmembers:
Half-inch BC plywood, cut to size & shape:
Framing for mounting the walls. The gaps are for the bolts that hold the floor to the frame.
eggsalad
Postby eggsalad » Tue Oct 08, 2013 11:03 pm
Painted the frame with 2 coats of Rustoleum High-Performance oil-base enamel in Leather Brown:
The bottom of the floor is primed and painted with the same stuff and bolted down (no pic). This is the desert, so it's all the "undercoating" I think I'll need.
eggsalad
Postby eggsalad » Tue Oct 08, 2013 11:12 pm
A brief diversion...
The hitch is mounted:
The HF LED taillight kit is installed and wired, along with a license plate mount:
So that the self-aware, soon-to-be camper can pick up its own lumber:
eggsalad
Postby eggsalad » Tue Oct 08, 2013 11:15 pm
Couple of side walls go up:
Then the back wall is temp'd into place, so I can nibble away at the bottom corners to tuck inside the frame drop:
eggsalad
Postby eggsalad » Tue Oct 08, 2013 11:19 pm
When I saw how my sketched design looked "in the flesh", I hated it. It was essentially a 4 foot cube with a "nose cone". Instead, I decided to go with a full wedge profile.
So I whacked off the tops of the walls:
Cut down the back wall, too, and cut the opening for the door:
eggsalad
Postby eggsalad » Tue Oct 08, 2013 11:22 pm
Brief diversion...
This door came off a full-height camper shell at the junkyard. It wasn't pretty, but for $30, I couldn't resist.
Inside is primed:
And painted "Unmellow Yellow":
eggsalad
Postby eggsalad » Tue Oct 08, 2013 11:27 pm
Here you can see the forward 3 walls, primed and attached to the floor. Also, the roof framing is starting to go in.
(Yes, I'm aware that I'm building this "inside out", i.e. framing *after* the walls are up. It's the best I can do.)
Framing for the 14" x 14" roof vent. You can also see where I finished framing the door jamb.
Lots of triangles make the roof really beefy:
eggsalad
Postby eggsalad » Tue Oct 08, 2013 11:31 pm
First finish coat is on. Starting to look like something:
The door is hung:
And the sub-roof, 3/16" Masonite, is cut and partially installed:
That brings us up to today. More to come. Thank you for reading my build thread,
eggsalad
eggsalad
Postby Ron Dickey » Tue Oct 08, 2013 11:39 pm
Welcome,
You may have more room then you think. You can put in shelves over head or by the door. You could raise the floor a little and have room to store some bring alongs. like stove, canopy, table. which way is you head?
Ron
173882......173887
Ron Dickey
Images: 787
Postby eggsalad » Tue Oct 08, 2013 11:43 pm
Ron Dickey wrote:Welcome,
Ron
Thanks for the welcome, Ron. Sleeping position will be "head to the rear". That's why the door is offset, so I can "sit up in bed" on a 4" foam mattress, with my back against the rear wall. Eventual plans call for shelving & storage on the driver side wall.
eggsalad
Postby Cantputt » Wed Oct 09, 2013 7:02 am
You are making good progress. There is a certain satisfaction for doing it your way vs following the book. Keep it up. :applause:
Cantputt
Images: 38
Postby eggsalad » Wed Oct 09, 2013 11:40 am
Cantputt wrote:You are making good progress. There is a certain satisfaction for doing it your way vs following the book. Keep it up. :applause:
Thanks, Cantputt. My skill level and tools force me to do it my own way. I see what others here have done, and I know I could never duplicate those techniques. Heck, even with what little I've done, I've had to learn and figure things out and "wing it" just to get this far!
:lol:
eggsalad
Postby KCStudly » Wed Oct 09, 2013 2:38 pm
I feel the same way, too.
Everything is relative to our own personal experience.
You will be camping very soon! :thumbsup:
